Lug conversion kit
Old Mar 22, 2005 | 06:06 PM
  #101
jimz68's Avatar
jimz68
Originally Posted by Hammer
You're not driving hard enough!
Wanna Bet? Why do I have to keep wiping my passengers face-prints off the side window ?
Jim
Old Mar 22, 2005 | 07:43 PM
  #102
Hounddog's Avatar
Hounddog
Pilo Stud conv kit
Originally Posted by MiniPilo
If enough people want the stud conversion kits, I can do a group buy on the Pilo Racing Kit. say, 25% off?
http://www.piloracing.com/shop/prodd...gNutKit&cat=18
Dan,
Count me in, I want a set with red cap type A locking set.
Wayne
Old Mar 22, 2005 | 07:58 PM
  #103
MiniPilo's Avatar
MiniPilo
Originally Posted by Hounddog
Dan,
Wayne
We have moved the price 25% lower permanently. Always 49 every day! They do not make a locking set in red though. Only chrome.
Old Sep 5, 2005 | 07:11 PM
  #104
xizor's Avatar
xizor
Originally Posted by TWISTER
I'm interested in geeting some feedback from users that have done this mod. Pros and cons needed. For info on the product look here.
I'm bumping up this thread because it has some good information about the stud conversion. I purchased 37mm studs from Pilo Racing and installed them with McGard splinedrive lugs/locks that I had from another car. FYI Pilo's are 12x1.5, so if you get seperate lugs, make sure to get the right thread pitch.
I started the method to exhange the studs while on the car, removing 2 bolts on a wheel, then putting some red loctite on a stud, and screw it through the wheel hole into the hub. I took a hex end and tightened the bolts tightly, and torqued the nut down to 80ft/lb.
Very easy process overall and a great mod.
Old Sep 6, 2005 | 07:32 AM
  #105
apexer's Avatar
apexer
A good tip. After removing the old lug bolt, spray the hole with brakeclean then blow out the hole to make sure everything is dry. This will make sure the loctite Red will hold the stud in the hole. BTW: I think 90 lbs. is a more proper torque value.
Old Jan 28, 2007 | 02:47 PM
  #106
CynMini's Avatar
CynMini
Originally Posted by MSFITOY
Wow...missed this thread altogether. Here's mine from BMP. More expensive than Pilo's But, I wanted black. These are 50mm with hex head. The nuts are 20mm long/forged/anodised alloy open type.
Is 50mm the whole length of the stud or just the part that sticks out of the hub? Turner has these, http://www.turnermotorsport.com/html..._ID=TWH9950B62. How long are these compared to yours? They will be going on a set of 15" Pro Race 1.2's Are your lugs 17 or 19 mm wide?
Old Jan 28, 2007 | 02:53 PM
  #107
MSFITOY's Avatar
MSFITOY
hmmm...I'm not sure now because I never measured it...butPromini says that the 50mm stud conversion will support up to 25mm spacer
Old Jan 28, 2007 | 02:56 PM
  #108
CynMini's Avatar
CynMini
I like these Turners, but I don't want them to stick out by 25mm. Are your lugs 17 0r 19mm wide?
Old Jan 28, 2007 | 03:11 PM
  #109
CynMini's Avatar
CynMini
I think I'll just go with the BMP studs. In that pic are you using any spacers?
Old Jan 28, 2007 | 03:28 PM
  #110
MSFITOY's Avatar
MSFITOY
Yes...5mm
Old Jan 28, 2007 | 03:30 PM
  #111
MSFITOY's Avatar
MSFITOY
I think they are 19mm long sleeved nuts to fit over the studs (uses 17mm metric wrench)...they cover the exposed studs as seen in my photo...
Old Jan 28, 2007 | 05:44 PM
  #112
onasled's Avatar
onasled
Wow, old thread! I just have to mention that it was funny coming across Tontobird, a member that does not post here anymore. Tontobird is a good friend of mine and she and I still talk. Last year Michelle raced Spec Miatas in NASA. She raced something like 18 races and ened up as rookie of the year in both NASA mid atlantic and Spec Miata. That's two seperate awards.
Michelle was the person that really got me started with this whole track thing. By the way she still owns two Ss and just had a new Spec Miata built for her for the upcoming 2007 season.
Just thought I'd give here some kudos here.
Old Jan 29, 2007 | 05:58 AM
  #113
MiniPilo's Avatar
MiniPilo
The stock Length is a 37, stud a 50MM stud would allow for up to about 15mm spacer. For 25mm spacer, you normally bolt the spacer into the wheel hub, and bolt the wheel to the spacer...
Old Feb 4, 2007 | 08:55 AM
  #114
mitchman's Avatar
mitchman
I wanted to buy the Turner set because they seem to be the most durable. But I called Turner about the BMP lugs, and they said theirs are all too long to fit under the factory wheel caps. So now I'm trying to decide between Pilo Racing and ProMini kits. Pilo is MUCH cheaper, which worries me a bit. I autocross the car quite a bit, so I'll be changing the wheels 2-3 times a month from April - October.
I see that Pilo now has a "race version" kit for people that change their wheels frequently (me!). But they don't have an allen head on them.
I'm going to be switching between the heavy 16-inch X-lites and my SSR race wheels. Any advice?
Old Feb 4, 2007 | 09:04 AM
  #115
MiniPilo's Avatar
MiniPilo
Not sure where you heard they do not have an allen head on them. They do have that as that is the only way to install them
Old Feb 4, 2007 | 09:14 AM
  #116
mitchman's Avatar
mitchman
Huh? According to this image on your website....
Old Feb 4, 2007 | 09:18 AM
  #117
mitchman's Avatar
mitchman
These are the one's I'm looking at from ProMini:
http://www.promini.com/product-exec/...arch_model/100
Old Feb 4, 2007 | 09:33 AM
  #118
moreorless's Avatar
moreorless
I see allens in both images if that's what you're trying to point out..
....Les
Old Feb 4, 2007 | 09:35 AM
  #119
mitchman's Avatar
mitchman
Okay, I'm blind......I see them now. Sorry
Old Feb 4, 2007 | 11:11 AM
  #120
MiniPilo's Avatar
MiniPilo
No problem. We are selling ALOT of these lately and are having trouble keeping them in stock. I hope to catch up on all shipments this week
Old Feb 4, 2007 | 12:40 PM
  #121
xizor's Avatar
xizor
I have the non race Pilo ones and changed my wheels many many times for autoxing and have never had a single problme
Old Jul 9, 2007 | 03:21 AM
  #122
holy mini's Avatar
holy mini
I just read through this whole thread (man it took me a while) and am now ready to ask my question... I am running 20mm spacers. Am I going to be able to do the stud conversion? (which brand if so would be best.) I do plan on doing AutoX and am running the Brembo Big Brake setup.
Thanks in advance.
Old Jul 9, 2007 | 06:00 AM
  #123
MSFITOY's Avatar
MSFITOY
Thanks in advance.
My 50mm conversion will handle up 25mm spacers...although, the thought of that makes me cringe...the bearing will be screaming murder from that kind of offset...
Old Jul 14, 2007 | 09:37 PM
  #124
JMH's Avatar
JMH
This is a great thread and I just read it start to finish. I do have a couple of questions as I am making this conversion:
1. What is the recommended torque value for the studs?
Someone posted "hand" tight, and others posted 80 to 90 ft/lbs. I would like to hear from those that have not had any issues with the studs backing out and that used Wet Red Loctite.
2. What is the recommended torque for the nuts?
Someone posted 90 ft/lbs and other threads the range has been 100 to 130 ft/lbs.
3. Are studs and nuts available in different thread pitches?
If so, what would be the purpose of shallow thread pitch on lugs?
Old Oct 23, 2007 | 11:27 PM
  #125
ninjlao's Avatar
ninjlao
Ninja Mini
you dont need an allen to screw them in. In my opinion depending on how deep the allen holes are, it would probably make the studs weaker. To put them on all you need is 2 nuts for that thread pitch.
Then you put both of them on, and you turn the inside nut counter-clock wise and the outside clockwise basically locking them in(just like a spring perch on a coilover) Then you can tighten the studs.
