All Season Tires for 2013 Mini
Old May 26, 2016 | 07:51 AM
goldenk02's Avatar
goldenk02
Hey all, I currently have the Hankook Optimo H426 P175/65R15 tires, 60k mile prorated, and I only have 27k on them and they already need to be replaced. I do mostly highway driving with nothing crazy. I have the 2013 Cooper Hardtop.
Any recommendations on all season tires that will not wear so quickly?
Old May 26, 2016 | 08:53 AM
hsautocrosser's Avatar
hsautocrosser
http://www.tirerack.com/tires/tires....omCompare1=yes
Compare the ratings for those tires to the Optima 426:
Make sure you rotate for maximum mileage no matter which tire you buy.
Old May 26, 2016 | 01:00 PM
kyoo's Avatar
kyoo
i like my conti true contacts
Old Jul 17, 2016 | 08:51 AM
vixster's Avatar
vixster
for 2008 r56 hardtop..
would you recommend this all season? or stick to the above mentioned by hsautocrosser?
http://www.tirerack.com/tires/tires....&affiliate=FH8
thanks
Old Jul 19, 2016 | 09:35 AM
Alex@tirerack's Avatar
Alex@tirerack
...would you recommend this all season? ...
http://www.tirerack.com/tires/tires....&affiliate=EZ3
DWS06 is the newer version on the same tire with better dry handling characteristics. the DWS is discontinued. What tire size are you looking for? How much snow do you deal with?
Old Jul 20, 2016 | 12:01 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Being that you are in Nashville you may see some cold temperatures.
For longer wearing tires and comfortable ride you can try Grand Touring All Season tire class and you don't need to keep the 175/65-15 OEM tire size.
You can use 195/60-15 which fits the MINI 15" wheel fine and will give you a larger tire selection to choose from.
see
http://www.tirerack.com/tires/survey...earDiameter=17
Of these the premium riding tire is the Michelin Premier A/S for $122 each.
Good handling dry or wet, OK in light snow or cold, comfortable and longer wearing (640 treadwear).
What is your budget?
If you must use 175/65-15 or are on a limited budget then-
Goodyear AltiMax RT43 for $68 each
Look at the tires that got worn out early, were only the front tire edges worn badly? If so then you would be better off rotating tires front to rear every 4000 miles since front tires wear out twice as fast as the rears if you don't rotate them.
Old Jul 20, 2016 | 04:34 AM
vixster's Avatar
vixster
175/65 R15
what is 84h? thats on the current tire.
I'm in metro NYC area.. every year is now a gamble.. past year, not much snow. year before, so much, they asked peeps to stay off roads till plowed! so, not much snow then as well So, I would say NOT deep snow.. roads are plowed...
Thanks again for your help!
Old Jul 20, 2016 | 08:59 AM
hsautocrosser
Load and speed ratings. Try TireRack.com for answers to common tire questions.
Old Jul 20, 2016 | 01:26 PM
isamin's Avatar
isamin
Smaller diameter wheels rotate more per mile than larger diameter wheels therefore the rubber on the tire is subjected to more friction (wear) . Tire rotation (regardless of what MINI says) will make your itty bitty wheels/tires last longer. Double deuces on a donk will out roll yours by miles.
ISAMIN
Old Jul 20, 2016 | 03:28 PM
hsautocrosser
Smaller diameter wheels don't rotate independently of the tires fitted on them. 15-16-17" hardtop OEM tire diameters usually vary from 24.0 to 24.6". For reference, worn out tires are typically 0.5" smaller than new.
Old Jul 21, 2016 | 05:31 PM
minihune's Avatar
minihune
ISAMIN
Wheel diameters are 15", 16" or 17" and will fit various tire sizes
Tire diameters are based on the exact tire size such as 195/55-16 or 205/45-17 which give you OEM tire diameters. Tire diameters can affect the number of tire rotations per mile.
Old Jul 31, 2016 | 03:09 PM
cptplt's Avatar
cptplt
I put Bridgestone Driveguard runflats 195/60-15 on my 12 Justa replacing the stock Contis. Have been very happy after @8K so far and much better in wet than the stock tires. Ride is as good as the stock 175/65-15 and better than the Dunlop wintersport 195/65-16 I use in winter (from my 11 convertible). I wont be putting much snow time on these but they are supposed to be all season.
Bludevilx
Dec 20, 2018 01:29 PM
ti22fjc
23
Apr 25, 2016 05:42 PM
SCHerzig
Apr 21, 2016 03:12 PM
jeffcutler
R57 :: Cabrio Talk (2009+)
Apr 6, 2016 10:36 AM
cooperScaleb05
Mar 13, 2016 08:00 PM
