R53 Wheel Fitment & Look with 15's
Old May 6, 2016 | 10:51 AM
Alias2k15's Avatar
Alias2k15
I came across a used set of used 15x7 ET30 4x100 TRM C1M wheels, but I cant figure out if they will fit my MINI or not.
I have an 06 MCS with stock suspension and OEM 17's.
My other concern is that the tires are 195/50/15, and I believe this might be outside of the recommended size. While they might be ok, I think the wheel gap will be huge and could look ridiculous. If the deal is right, I could always try to resell the tires and get something slightly bigger to mount on the wheels.
Does anybody know if these wheels will fit the MINI? Also, I cant seem to find any pictures (other then winter set-ups), but is anybody running 15's with the stock ride height/suspension?
Old May 6, 2016 | 01:03 PM
Gitmoe's Avatar
Gitmoe
They'll fit...
CLICK HERE FOR PICS.... NO, SERIOUSLY.
Old May 6, 2016 | 06:37 PM
Alias2k15's Avatar
Alias2k15
Originally Posted by Gitmoe
Thanks, but if you click on that link and look at the pictures almost all of those MINIS are lowered.
Do you know first hand that the wheels will fit? I think that 30 offset might rub.
Old May 6, 2016 | 10:56 PM
Anakist's Avatar
Anakist
Try Tirerack and see if they sell those wheels or something with similar offset. Their wheel chooser seems to be pretty good.
I put 16x7 Enkeis with 43 offset and 205/55-16 Conti tyres on my 04 R53. 13mm extra seems like a lot, but there is a fair bit of room between my tyres and the guards.
James
Old May 8, 2016 | 06:37 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Do you have JCW front brakes? The calipers are larger than the standard front brake calipers for the R53.
With 15x7 et30 compared to OEM MINI wheels and tires:
You will be 11.7mm further from the inner suspension and poke out 24.4 mm more, which is quite a bit.
175/65-15 is the OEM tire size for the 15x5.5" OEM wheel on the base cooper.
195/50-15 is too small a tire diameter for daily street driving.
For a 15x7" wheel, you can try 195/60-15 which gives you a good tire selection and will fit OEM suspension.
So yes it will fit but it will poke out an inch.
Old May 8, 2016 | 07:32 PM
Gitmoe's Avatar
Gitmoe
You can run a 16x8 ET30 lowered and not rub. It won't "poke out" an inch. A 15x7 ET 30 will still sit under the fenders no question. It will be about 1.5" further out towards the fender than a stock 15" wheel.
This is a great wheel fitment calculator I use often... http://www.willtheyfit.com
Old May 28, 2016 | 08:12 AM
sabjcw's Avatar
sabjcw
Alias, they'll absolutely fit with standard R53 front calipers. However, it'll look ridiculous unless you really lower your car.
I run 15x8 Enkei RPF1's with a 28et, 205/50's, lowered on PSS10 coilovers and there is ZERO rubbing. 30et's and 7" wide will never rub.
FYI, lightweight 15's on an R53 are THE way to go. You will love it! It's a completely different car.
Old May 28, 2016 | 08:16 AM
sabjcw's Avatar
sabjcw
http://cimg1.ibsrv.net/gimg/www.nort...4722815aeb.jpg
Just to give you an idea as to what it looks like.
Old May 29, 2016 | 05:42 PM
SKurj's Avatar
SKurj
Any idea if those would fit over JCW brakes?
Old May 31, 2016 | 01:25 PM
minihune's Avatar
minihune
JCW brake calipers are larger than stock R53 calipers so no, 15" wheels don't fit. Some 16" may fit and usually 17" wheels are better for clearance.
Old Jun 8, 2016 | 09:01 AM
jasonsmf's Avatar
jasonsmf
Many 15" wheel options DO fit over JCW (or R56 S) brakes.
I've run 205/50/15's as a street tire, even when I was "stock". Other than a little wheel gap, that size is awesome! 195/50's would only be ever so slightly shorter than the 205/50's, hardly noticeable.
Jason
Old Jun 8, 2016 | 11:04 AM
MINIAC's Avatar
MINIAC
Both those sizes exceed the recommended ±3% variance from stock ... 205/55-15 and 195/55-15 are the appropriate sizes.
Old Jun 8, 2016 | 11:08 AM
jasonsmf's Avatar
jasonsmf
I'm not certain where this 3% number comes from. I can assure you, this tire size works really well for me.
Jason
Old Jun 10, 2016 | 12:55 PM
Alex@tirerack's Avatar
Alex@tirerack
It's an tire and wheel industry rule of thumb for speedometer and odometer error margin.
Old Jun 10, 2016 | 01:18 PM
jasonsmf's Avatar
jasonsmf
Fortunately for me, I work in a different industry, so I'm not bothered by a little error in my speedo and odometer
(I kid, I kid...)
Jason
Old Oct 16, 2021 | 03:31 PM
Vacajay's Avatar
Vacajay
That setup looks sweet!
Old Oct 16, 2021 | 03:46 PM
cmt52663's Avatar
cmt52663
Kosei 15x7 +38 - running either 205/50-15, or for competition 225/45-15. This is Gollum I circa 2008.
Cheers,
Charlie
Pauley04
Tires, Wheels, & Brakes
May 30, 2018 08:55 PM
Alias2k15
Nov 21, 2015 08:44 PM
Crisseh95
Jan 12, 2015 07:33 PM
RA082324
Feb 27, 2012 12:48 PM
R53.0131
Jul 23, 2011 06:38 PM
