Newbie: Will 16x8.5 +20 fit?
Old Dec 13, 2015 | 12:46 PM
R5609's Avatar
R5609
I just bought my 2009 Mini S and purchased a set of wheels, 16x8.5 +20
I don't enjoy hitting road grooves and swerving with the stock 205/45/17 tires
My questions is, will 215/50/16 fit fine with no rubbing/issues. or 225/50/16?
I am on stock suspension and would love to have a more comfortable ride and wide tire for the raining Portland weather. Please let me know if any of you have pulled this off! Cheers
Old Dec 13, 2015 | 01:19 PM
MINIAC's Avatar
MINIAC
That wheel width and offset is pretty radical for a MINI. I doubt you'll be able to run tires that wide. Any tires you run will be stretched.
Do a search for "16x8"
Old Dec 13, 2015 | 02:22 PM
R5609's Avatar
R5609
I've done some research but can't seem to find anyone running a 50 tire. Usually people run a 40 or 45 which gives such a bumpy feel.
Old Dec 13, 2015 | 02:57 PM
MINIAC's Avatar
MINIAC
Were the 205/45-17 tires runflats? If so you can run 215/45-17 conventional tires on your stock wheels to get more cushioning.
Because of their width and offset those 16" wheels aren't really appropriate for addressing your problem. With 16x7 wheels that have a closer to stock offset you could run 205/55-16 tires for a more comfortable ride.
Old Dec 13, 2015 | 05:15 PM
R5609's Avatar
R5609
I believe the stock tires are still on the car. Probably will go with 215/45/16 since I have already purchased the set of wheels.
Old Dec 14, 2015 | 08:50 AM
MINIAC's Avatar
MINIAC
You will have very few tire choices in that size.
Old Dec 14, 2015 | 05:36 PM
MiniRoadstah's Avatar
MiniRoadstah
The factory offset for a Mini is 45 mm. You can generally get away with an OEM tire size with 42 to 40 mm offset. Those offsets would put the wheel and tire on the edge of the outside edge of the wheel/tire right in line with the car's wheel well edge. A wheel with a 20 mm offset would bring the tire edge out beyond the wheel well. You may end up with interference issues at that 20 mm offset.
Old Dec 14, 2015 | 06:12 PM
R5609's Avatar
R5609
Do you guys think 225/45/16 will fit without any issues? Considering stock wheels were 17x7 on my MCS.
Old Dec 15, 2015 | 04:30 PM
MINIAC's Avatar
MINIAC
Again ... you will have very few tire choices in that size.
From Wheel-size.com ...
From WillTheyFit.com ...
Old Dec 15, 2015 | 05:19 PM
MiniRoadstah
Very few tire choices, that are fairly soft, high performance so will wear rapidly from what I could find at TireRack.
Might wanna ask in the { Roll call 8"+ wide wheels} thread right here in Tires, Wheels, & Brakes. Some of these guys are messing around with some wide wheels in smaller offsets.
Old Dec 17, 2015 | 03:49 PM
R5609's Avatar
R5609
Think I will go with 225/45/16
Old Dec 20, 2015 | 05:09 PM
R5609's Avatar
R5609
Anyone try this fitment?
PelicanParts.com
Suspension Products
May 17, 2016 08:42 AM
Ali_C_911
Nov 3, 2015 07:36 PM
Oct 29, 2015 11:04 AM
Suspension Products
Oct 29, 2015 10:23 AM
KG-CMF
R55 :: Clubman Talk (2008+)
Oct 28, 2015 01:35 PM
