Plus Size Rotors for R56?
Does anyone make plus size rotors for the R56 MCS? I'm thinking about going to 18" wheels and wanted to go up one size for the rotors.
I like the slotted/drilled rotors. It would be great if someone made plus rotors that were slotted/drilled too.
Well you can't just get larger rotors on any car. You would also need larger calipers and different brackets to accommodate them. This is generally referred to as a big brake kit (BBK). outmotoring, waymotorworks, detroit tuned and others all cary them.
Same situation here; larger rotors require one of two things- either a complete big brake conversion of calipers as well or 'relocation' brackets for fitting the stock caliper onto a bigger rotor. With the price point of and entry level kit like the Wiwood 12.2 kit at $859 total I can't fathom the value of the second option really.
thebordella
Aug 31, 2015 01:37 PM
Aug 25, 2015 09:18 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
