Brake pad indicator light on
Old Jan 5, 2011 | 05:08 PM
minirooferS's Avatar
minirooferS
My brake pad idiot light came on recently and I'm wondering why because I had the front pads done about 5k miles ago. Is there a sensor for the rear pads as well?
Old Jan 5, 2011 | 06:30 PM
Crashton's Avatar
Crashton
Yes there is. Left front & right rear.
Old Jan 5, 2011 | 06:54 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yup sounds like you now need rear pads.
Old Jan 5, 2011 | 09:22 PM
G0LDENDOMER's Avatar
G0LDENDOMER
i know this isn't the marketplace, but if you need a new sensor i have one sitting in a closet unopened from way.
Old Jan 6, 2011 | 09:56 AM
ThomasW's Avatar
ThomasW
Is there a way to turn the light off without getting new sensors? I just want to deal with my brakes on my own and not have that annoying light telling me I am not using the sensors.
Old Jan 6, 2011 | 10:13 AM
ntmid8r's Avatar
ntmid8r
You will have to splice or solder the wire together to complete the circuit.
(Brake sensor wire, that is)
Old Jan 6, 2011 | 12:14 PM
G0LDENDOMER
there is a way. i'm by no means a brake expert, but i do know that once the sensor is tripped it has to be replaced. if you want to totally bypass it, you can pull the sensor out, cut it off and twist the two wires together and then ziptie it to the chassis or something, or what a lot of people do is just buy the new sensor and ziptie it to the side also. i guess that leaves the option of easily reconnecting it when you go to sell or trade in, etc.
good luck :D
Old Jan 6, 2011 | 04:14 PM
Porthos's Avatar
Porthos
You can't do it on an r56 I tried. Because the person that sold me sensors sold me the one for an r53. So I tried splicing it till I could get a new. Guess what I did MTTS with the brake light on. All 5k miles of every time I started I had to deal with it dinging at me and the bright red light in my face at night. Don't be a cheap *** and spend the $20 and buy some sensors.
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
penguinhomey
Aug 17, 2015 01:33 PM
