wheel fitment
Old Dec 4, 2010 | 12:41 PM
tmoney's Avatar
tmoney
wheel fitment
I found a good deal on some OZs on cl. They are 17x7 with a 37 offset. How are these going to fit?
Old Dec 9, 2010 | 11:58 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
While they will fit they will stick out 14mm more than stock.
If you use stock tires and stock suspension it will work.
You can use more negative rear camber to tuck the top edge of the rear tires inward a little but do not be excessive in rear camber since that would increase tendency for oversteer.
Old Dec 10, 2010 | 01:28 PM
quikmni's Avatar
quikmni
I had 17x7 et38 wheels with 215/40-17 tires using H&R springs (almost an inch drop) on my 2003 MCS (R53). I had slight rubbing in the rear that required a little trimming of the plastic wheel arch and wheel well liner. Also with the lowering that added negative camber which provides a little more room. Thus, it will be close but should fit depending on the tire size and how much your car is lowered. It also depends on what year/model MINI you have.
Old Dec 10, 2010 | 04:23 PM
iwashmycar's Avatar
iwashmycar
https://www.northamericanmotoring.co...-question.html
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
Kimolaoha
Dec 5, 2020 09:32 PM
ASRman
Aug 13, 2015 09:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
