205/45/17 vs 215/45/17
Old Jul 8, 2011 | 12:09 PM
  #26
Quadrivium10's Avatar
Quadrivium10
Originally Posted by JackMac
40 vs 45 will not impact how the tires fit on the rim. This number represents the height of the sidewall as a ratio to the width of the tread. So basically, the 45 is a taller tire than the 40 when both start from the same width (i.e 215)
FWIW, conventional wisdom is that a narrow tire and taller sidewall combination is better for snow. In the past, I used Blizzak LM-22s which were outstanding in snow. They are considered a high performance snow tire, but really not so great on street due to the softer compound used.
Tirerack is a great resource, as you can get real customer feedback and surveys.
Awesome! Thanks so much!
Old Jul 9, 2011 | 06:55 AM
  #27
rjtrout2000's Avatar
rjtrout2000
Originally Posted by slinger688
I have run 205/40 17, 205/45 17, 215/45 17 and 225/45 17 tires on the car so far. My fab is 215/45 17 as the car is less buzzy on the highway and a little more comfy as well. All four tire sizes do not have rubbing issues on an unlowered r56 MCS. The turbo has enough power to overcome the slight increase in diameter of the tire.
The one I dislike the most is 205/40. Just more harsh and buzzy that I like it with my racing suspension and setup.
The only tire size I haven't run yet in this lineup is the 215/45-17. Now that you say that, it makes me want to test out the new track rubber even more though! I just bought a set of Kumho XS in that size. I'll bet they ride well and grip like crazy!
Old Jul 9, 2011 | 07:44 AM
  #28
MattyKHZ's Avatar
MattyKHZ
Here in the UK I went from ContiSport 3 SSR runflats in 205/45/17 on standard Crown Spokes to 215/45/17 ContiSport 3 non runflats on OZ Ultraleggera wheels.
Prefer 215 size but they do seem to kick up more dirt than the 205 size.
Old Jul 10, 2011 | 06:27 PM
  #29
rjtrout2000
With the extra width of that tire, I am not surprised! When I put my spacers on, I noticed that the car seemed to fling up some extra dirt here and there. The [rice to pay for moar wide!! lol
Old Jul 25, 2011 | 03:54 PM
  #30
wisaac42's Avatar
wisaac42
Replace 205/45R17 with 215/45 17 on lowered clubbie?
Time to replace my tires (as I waited too long after lowering the car to get new control arms, and now the rear tread is nearly bald).
From this thread I learned that I could replace the original 205/45R17 runflats with 215/45 17 tires if the car was not lowered, but I'm wondering if I can still do so if the car is 1-inch lower.
Anyone tried such a swap?
Old Jul 25, 2011 | 04:10 PM
  #31
slinger688's Avatar
slinger688
I am lowered about 1.3" and run 215/45 17 w/o any issues.
Old Jul 25, 2011 | 05:22 PM
  #32
AXO's Avatar
AXO
I am thinking about running 225/45/17's. What characteristic caused you to like 215/45/17 better?
Thanks AXO
Old Jul 25, 2011 | 05:35 PM
  #33
Clubman S Turbo's Avatar
Clubman S Turbo
Govtslug, I just lifted your comments because they are exactly the same. I got Firestone Indy 500s in the 215s size from TireRack.com and my Edge CS adjusted itself a whole 1 MPH after I input the values and chose "perform correction". In other words, real world, no difference. They looride, and handle worlds better than the "LackOfContact" Conti run-flat junk that I took off in 16" size.
I just switched from the stock 195/55/16's to 215/45/17. They fit fine and look a little beefier than stock. As far as the speedo, it barely had any effect on my '08 S Clubman. With the 16" tires, when the speedo said I was doing 60, I was actually going about 56 or 57. With the 17" tires it's closer to 57, maybe 58.
Old Jul 25, 2011 | 05:40 PM
  #34
wisaac42's Avatar
wisaac42
Thanks slinger. Do you have a favorite brand and model tire?
Old Jul 25, 2011 | 05:44 PM
  #35
slinger688's Avatar
slinger688
Thanks AXO
225 is slightly big in diameter. While it is almost right for the speedometer, the extra handling is not that needed for the street. There is a perceiveable drop in mpg and increase in road noise for the same tire. There is a very slight rubbing of the rear tire on the strut mount area in quick turns.
All said, I think 225 is fairly useable overall.
Old Jul 25, 2011 | 05:50 PM
  #36
slinger688's Avatar
slinger688
I generally run Dunlop Z1 Star Spec for summer and Conti Extreme Contact DWS all seasons for winter, both in the 215/45 17 size. Dunlops can be a bit noisy but they are great performance for dry and wet, especially wet. DWS all seasons can be a little vague in turn in but really quiet and comfortable but add a little psi (to 39 or so) and they are great.
Old Jul 25, 2011 | 09:42 PM
  #37
malteseracer's Avatar
malteseracer
Guys, place your hand behind your tire...if theres 5mm of space, it will fit.
Old Jul 26, 2011 | 05:31 AM
  #38
Clubman S Turbo
For the most part thats prob true, just be careful about turn radius and clearances changing when you travel over larger bumps, especially with some load in the tail end. You dont want to shave a tire on the fender edge or any suspension components. My 17"s fill out the wheel wells excellently, I have had people ask me how much I lowered the car and they are surprised when I tell them its stock ride height.
vbmike
Oct 15, 2015 04:32 AM
srhodes
Oct 8, 2015 05:17 PM
mbur1024
Tires, Wheels, & Brakes
Nov 3, 2003 12:28 PM
Chief_Charlie
Jul 14, 2003 10:38 AM
Alex@tirerack
Dec 4, 2002 05:03 PM
