Quite possibly the best racing wheel ever...
Old Oct 12, 2008 | 11:39 PM
ninjlao's Avatar
ninjlao
Ninja Mini
http://www.carbonfibergear.com/weds-...n-fiber-wheel/
That's 2.76 kg which is about 6lbs!
Old Oct 12, 2008 | 11:51 PM
svandoorn's Avatar
svandoorn
I don't think it can hold up on the race track. Probably a 100% show wheel.
Old Oct 13, 2008 | 01:05 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Sweet Weds makes quality wheels, not really a show wheel maker. $10-12 grand No those Dynamags are probably not cheaper like $6-22 grand the rims is magnisium and center is real carbon fiber, Mosler used them on their LeMans entries.
Old Oct 13, 2008 | 05:47 AM
RaceTripper's Avatar
RaceTripper
F1 wheels are also made from composites. They had one out for display at the '07 USGP. The wheel with tire inflated was about 10 lbs. My 14 yr. old niece was able to pick it up effortlessly. Very light, very strong, very expensive.
Old Oct 13, 2008 | 07:00 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Originally Posted by howsoonisnow1985
Sweet Weds makes quality wheels, not really a show wheel maker. $10-12 grand No those Dynamags are probably not cheaper like $6-18 grand the rims is magnisium and center is real carbon fiber, Mosler used them on their LeMans entries.
I saw a Mosler and the rim was CF while the spokes were magnesium--opposite to the way you have it.
Old Oct 13, 2008 | 07:23 AM
Bigshot's Avatar
Bigshot
No denting those puppies.....!
Old Oct 13, 2008 | 08:16 AM
minimarks's Avatar
minimarks
Very sweet.....very overbudget.
Old Oct 13, 2008 | 05:14 PM
jerjer's Avatar
jerjer
def an overkill too~
Old Oct 13, 2008 | 05:18 PM
ScottRiqui's Avatar
ScottRiqui
I think the 6-lb weight would be even more impressive if we knew the diameter/width of the wheels. Was it in the article and I just missed it?
Old Oct 13, 2008 | 08:35 PM
howsoonisnow1985
You're right, just googled mosler lemans images.
Not just Mosler usem but Koenigsegg and Ascari too
Warren Mosler said:"The MT 900S will be the first US production car with factory equipped carbon fibre wheels. The revolutionary 18 & 20 inch nine-spoke Dymag wheels sport a magnesium centre hub with carbon fibre rims. The front and rear carbon fibre rims weigh 14 and 17.5 lbs respectively, compared to the current used wheels which weigh 24 and 28.5 lbs respectively. This translates into a total reduction in rotating un-sprung weight of 42 pounds. The Dymag carbon/magnesium wheels have nearly half as much rotational inertia as forged aluminium wheels. And, of course, pursuant to our imperative for total performance, the large savings in un-sprung weight improves handling and ride qualities as well as our already extreme acceleration, braking and cornering."
Wow, that would make the fronts 18s weigh 7lbs and the rears 19s weigh 8.75lbs each.
Old Oct 13, 2008 | 09:23 PM
Dwell's Avatar
Dwell
"HI EVERYBODY! COME CAR JACK ME! MEEE! MEEEE! CARJACK ME!!!!!!!"
Old Oct 14, 2008 | 12:17 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
While light weight is good I wonder what is the risk of using something ultra light when the car itself has ample power.
If given enough torque the wheel due to less weight might lack the ability to keep in contact with the ground and tend to spin more easily.
A heavy wheel plus tire might be planted a bit more and resist spinning.
Might depend on the tire's ability to keep traction and how much torque is trying to rotate the wheels.
Once the car is going then less energy is needed to accelerate and less energy is needed to brake fast.
Old Oct 14, 2008 | 04:44 AM
RaceTripper
Maybe you aren't understanding the benefits of less unsprung weight. The effect is the opposite of what you are claiming. Lighter weight results in better contact with the road and more grip. That's why racing cars and high performance cars use lightweight suspension and wheel components.
The real downside is cost and reliability.
Old Oct 14, 2008 | 07:03 AM
GOTCURVES's Avatar
GOTCURVES
Lets look at these wheels as we would any other mod. What does it offer...unsprung weight savings, looks, & Rareity.
weight savings total...cheap light wheel Konig Feather @ 11 lbs and $100 ea.)
Weds c/f wheel...6 lbs and $2500 ea
Cost of weight savings = $480 per lb!!!!
Some how I think there is a much more affordable way to save unsprung weight, really though there's no way 5lbs per wheel will make that big of a difference when your already around 11 lbs in something affordable.
Old Oct 14, 2008 | 09:37 AM
UKCoopeR's Avatar
UKCoopeR
those weights are pretty insane
failure mode? not so sweet...
trade off i suppose
Old Oct 14, 2008 | 09:46 AM
ScottRiqui's Avatar
ScottRiqui
Well, I still don't know what diameter/width the pictured carbon-fiber wheel is, but if it's a 17" or 18" wheel, the savings could be a lot more than just five pounds per wheel. The lightest Konig Feather is almost 12 pounds (11.9), and that's in a 15" X 6.5" size. If you go up to the 17"/18" sizes, you're up around 17 pounds.
Still, I agree that the Weds wheel doesn't make much sense for anything other than an ultra-performance car where you've already spent mucho time/money making everything else as light as possible.
Old Oct 14, 2008 | 10:02 AM
r52pimp's Avatar
r52pimp
I will agree that Wed probably did not have us people with Minis in mind when they made those.
Old Oct 14, 2008 | 10:42 AM
DrPhilGandini
You get a set of Dymag CF/Mg wheels thrown in when you spend $330,000 on a Mosler. I really don't think they are for us Mini people like r52pimp suggests!
Still they are cool to look at--I've seen the Dymags in person and they are sweet.
Old Oct 14, 2008 | 10:47 AM
Darkness's Avatar
Darkness
I'm gonna order me a set and hang it on my garage wall
Old Oct 14, 2008 | 10:57 AM
r52pimp's Avatar
r52pimp
If I did that my SO would hang ME on the wall right next to them.
Old Oct 14, 2008 | 11:19 AM
Darkness's Avatar
Darkness
"oh, those are my track wheels, dear. I need to keep them off the garage floor and out of the way. Yep, yep, same as the cheap konings I had last year only with a difference finish. The old set got bent because they were left on the floor and I had to get rid of them! yes, yes, they were the same price. oh, btw, how about I do all the finanaces this year and you not worry about all that bank account gibberish?"
Old Oct 14, 2008 | 11:37 AM
r52pimp's Avatar
r52pimp
Wanna trade wives?
Old Oct 14, 2008 | 01:13 PM
RaceTripper
MY wife is smarter than that & she has car sense. When we did road trips in the M3, she could be asleep, but if I nudged it to 100 MPH she would wake up and tell me she knew how fast I'm going by the engine sound. No fooling her.
On the bright side, she loves ALMS & Speed World Challenge and insists we attend Sebring, Road America, and Petit Le Mans. She's a keeper.
Old Oct 14, 2008 | 03:52 PM
GOTCURVES's Avatar
GOTCURVES
All I would have to tell my wife is I promise these wheels will get us a national title and that could lead to sponsorship and wins that pay $ and I would have them! I just can't lie to my best friend like that. She shares my passion of Mini and autosports! She even wanted (and we needed) new 615's for the Mini for her birthday present!!!!!!
She could be 300lbs (she's not) and butt ugly (she's attractive) but with that kinda passion she's definately a keeper!!!!
ebowling
90
Aug 4, 2019 09:15 AM
eatsleepautox
Oct 30, 2015 06:46 AM
ltjpunk7
Sep 6, 2015 07:32 AM
ki7hy
Aug 12, 2015 07:07 PM
