KONI Vs. H&R Coil overs
Hi everyone,
So I recently changed my tires and got some Bridgestone SO3 215/45/17s on my stock R90s. Mini looks amazing, but when I loaded 3 other people in the car, I noticed some rubbing. Since I was planning on doing some suspension work at some point, I thought that now might be the best time to do that.
Although I am not set on using either Koni or H&R adjustable coil overs (ie i am open to other suggestion like other brands, other systems etc) I've been looking at the KONI and H&R adjustable coil overs.
The main reason for the "upgrade" is to get rid of the occasional rubbing. I do not want to lower the car too much because there are places where my car already hits the ground, so I am looking for a solution that will satisfy this.
The mechanic at Mini did not really offer any help other than telling me off for changing from 205s to 215s, but he said I might be able to put in a spacer at the top of the shock which would lift the back a little and should, in theory, solve the rubbing problem. I've never heard of this so am putting out to see what everyone thinks.
I was also told that adding cambers and fiddling with the angles could help, but that it would also increase the wear on the tires.
I know that other people have had rubbing problems, and I also know that many have put in the same size tires as me (215/45/17) so please help...tell me what you have done or what you would do.
Thanks in advance,
Louay
Thanks in advance,
Louay
IMO, can't go wrong with Koni. Coming from an SCCA family, I'm pretty biased.
I think the Koni's use stock type springs. The coilover's you can adjust height without changing the spring.
_________________
-goin440
IB/IB MC on 17" Volks
_________________
-goin440
Inside the Fender lip.
I heard about fender rolling (or something like that) so I think I'm gonna try this first.
Does anyone know if Bilstein is developing PSS 9 for the mini? If so I'll definately hold out for that :smile:
yes they are, but still no word on USA availability...
squawSkiBum
Oct 2, 2015 09:21 AM
sabjcw
Aug 14, 2015 07:40 AM
ki7hy
Aug 12, 2015 07:07 PM
