Time to replace my RF Tires
Have gone thru about 20+ pages on this Tire and wheel forum and got tired go'n any further. Looking to replace my Perrilli OEM Run flats..cant believe I only got about 12K on'em..Goodyear Eagles RSA's are about 8 lbs heavier and more expensive..Dunlop SP Sports lok like there are for summer only driving. Looking for a higher milage all wx tire and a bit less expensive than the OEMs.. suggestions??
Are you trying to use these tires for snow as well?
For general use non runflats some people like:
Yokohama AVS ES100 or Bridgestone Potenza Pole Position S-03
Both are worth a look and available at tirerack.com
Yes..I'm looking for an all season, higher milage tire to replace my OEM's. The Perellies are horrible in the snow and the milage is atrochous (less than 12K). However the Goodyear 'Eagle' RS-A EMT is more expensive and about 8 lbs heavier per tire. Any other worthy tire to look at?
This is a great performace all season tire, 950. What charteristics would you like that it doesn't have?
Alex
Alex
>>Alex
Hi Alex,
Didn't see my tire spec on your website for 205/45R 17 for the Bridgestones..also the site said they are 'H' rated..also are they Run Flates?
Thanks,
Clay
>>Alex
Hi Alex,
Thanks,
Clay
try a seach to see the tactics.
often a cell phone - a roadside plan, a 12v comprssor, and a can of fix'o flat.
I think in the lower profiled sides 950 is a great choice, if you want all season, and dont need razor sharp steering - very comfortable !
Alex
Alex
>>Alex
Thanks Alex. That's the way I was leaning, but just looking for some other ideas.
>>Alex
>>For those of you swapping out Run Flats for non-Run Flats, are you just accepting the risk of a blow out, or are you taking other measures?
>>Spike
probably has been answered on previous posts..but can I replace non-run flat tires on Run Flat rims?
>>Spike
Hi Tom
Try seaching custom, size 215/45/17
or see it here
Re 950 H rated
or
RE 950 W rated
Alex
>>Alex -- you recommended
>>>>Bridgestone RE 950 45k $142 ea!
>>But when I use your website, I don't see the RE950 pop up under either 16" or 17"
>>Am I doing something wrong?
>>Tom
or see it here
Re 950 H rated
or
RE 950 W rated
Alex
>>Tom
>>Tom
Yo Tom,
Got any Ham gear in that Mini yet..
Clay AA3JY
>>Tom
Yo Tom,
Clay AA3JY
>>45,000 miles
>>Alex
>>>>What kind of milage would I'd expect on these tires?
I guess anything is better than the 12K on the Perellies OEM's
>>Alex
>>Rotation every 3-4k will help dramaticalli, even on the OE Eufori
>>Alex
>>>>I guess anything is better than the 12K on the Perellies OEM's :smile:
>>Alex
