18" Rim Question? R56
Old Mar 2, 2008 | 09:53 PM
masterd78's Avatar
masterd78
MANIAC
Could I run these wheels?
http://www.wheelmax.com/product.asp?ProdId=17505
On my current setup, which is H&R Springs, and Alta Control Arms? Is the offset ok? Also is the 7.5" width alright? Oh and would 215/35 for the tires be alright?
Thanks wheel guys and gals.
Old Mar 2, 2008 | 11:16 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You need to check with the vendor about fitment for the front brakes and 14mm bolts for the R56 and with Tire pressure Monitoring System.
Your wheel size and tire size are fine even with H&R springs. Tire diameter will be 23.9" which is smaller than stock.
What tire are you planning on?
Note: you need 4x100 bolt pattern. I don't think the wheel is very lightweight. Likely 20+ lbs.
Old Mar 3, 2008 | 10:04 AM
masterd78's Avatar
masterd78
MANIAC
My problem is that I want white wheels with like a 7 to 10 spoke design. Not alot of options out there. I want 18's but might end up with 17's because of fitment. Most of the white 18's are either 7.5 or 8 wide. Any other thoughts?
Old Mar 3, 2008 | 12:05 PM
Wake|MCS's Avatar
Wake|MCS
You could run 7.5J and 8J wide wheels no problem. What's your budget as that plays a big role on wheel selection. Look for something like an ET42 and you'll be fine.
On the R56 I wouldn't go with any tire size other than 215/40/18 cause it's a much bulkier looking car than the R53. The 35 series would be too thin IMO.
Best of luck.
Hippiehobbit267
Dec 3, 2019 04:22 PM
FLYM1N1
Oct 13, 2015 04:33 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
thebordella
Aug 31, 2015 01:37 PM
Bennyboy
Aug 18, 2015 07:28 AM
