Just got a Michellin Tire question
Old Feb 7, 2008 | 02:39 PM
2packt's Avatar
2packt
hi... im getting the michellin pilot exalto.... 205/45 17....i was wondering if this was same name as michellin pilot exalto PE? i went to tirerack and couldn't find exalto without the words PE? help please? thanx.
Old Feb 7, 2008 | 03:59 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
From Tirerack.com
Ultra High Performance Summer tire
Michelin Pilot Exalot PE2
http://www.tirerack.com/tires/tires....lot+Exalto+PE2
205/45-17 240 treadwear W speed rated $124 each on backorder
High Performance All Season tire
Michelin Pilot Exalto A/S
http://www.tirerack.com/tires/tires....t+Exalto+A%2FS
No sizes fit the MINI in 17".
205/55-15 and 205/50-16 both will fit smaller rims for the MINI.
400 treadwear U speed rated
So for the size you got you have Pilot Exalto PE2. This is not for any snow use, otherwise a very good tire for the MINI.
Old Feb 7, 2008 | 04:11 PM
minimarks's Avatar
minimarks
PE 2s here and they are a fantastic tire! I got the 215/45/17. PS; Have the A/S on the wife's Beemer and their great too.
Old Feb 7, 2008 | 06:48 PM
2packt's Avatar
2packt
decision
that's awsome...hmmm...would getting 215 very diffferent? cost wise itz like 40 more for each tire...what should i do?
Old Feb 7, 2008 | 07:54 PM
minimarks's Avatar
minimarks
Old Feb 7, 2008 | 07:57 PM
minihune's Avatar
minihune
that's awsome...hmmm...would getting 215 very diffferent? cost wise it's like 40 more for each tire...what should i do?
Stick with 205/45-17 ($124 each vs $167 each for 215/45-17).
For stock 17x7 rims the 205/45-17 will work fine (fits rims 6.5-7.5" wide). It's 20 lbs each which is 2 lbs less per tire than 215/45-17. It's wide enough and handles fine.
For 17x7.5 or 17x8 rims then 215/45-17 is a better match than 205/45-17.
215/45-17 is also taller than stock tires so you get less wheel gap, and some speedo and odometer error. Nothing major.
Old Feb 7, 2008 | 08:00 PM
minimarks's Avatar
minimarks
Dang, got them here for $158.00 mounted and balanced....
Old Feb 7, 2008 | 08:11 PM
QXXOTIC's Avatar
QXXOTIC
Michelin Stuff
I think there is a Pilot Sport as well as the PE-2. Mine are the 205's
I have been running the PE2 for almost 33,000 miles and they are probably the BEST tire I have ever used,, and that is an A+ for handling as well as wear!
All in all a great buy!
Have fun!
Jim
Old Feb 7, 2008 | 08:16 PM
minimarks's Avatar
minimarks
Had a set of the sports on the wife's car, great handling tire but they were toast in about 11,000 miles and she doesn't drive very hard...
W0TM8
Dec 19, 2019 07:50 AM
Mini'mon
Aug 16, 2015 04:15 PM
Mini'mon
Aug 16, 2015 12:47 PM
Emnotek
Aug 13, 2015 05:47 PM
jrezzo
Aug 9, 2015 10:32 PM
