Motegi DP6 18x7.5 45mm offset?????
Old Feb 5, 2008 | 02:51 PM
#20Works4me's Avatar
#20Works4me
Hey Guys, I'm considering an 18" set of these for an 06 MCS I might buy and was wondering if anyone had a set of these in 18's on their car? They are Motegi DP6 silver18"x7.5", I'm a little concerned about the offset = 45mm any issues? with a 205/40/18 tire?
Old Feb 5, 2008 | 04:27 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
[quote=Ovrezee;2022968]Hey Guys, I'm considering an 18" set of these for an 06 MCS I might buy and was wondering if anyone had a set of these in 18's on their car? They are Motegi DP6 silver18"x7.5", I'm a little concerned about the offset = 45mm any issues? with a 205/40/18 tire?
quote]
You should be fine using stock suspension. +45mm offset is OK with 18x7.5 wheel and 205/40-18 tire.
Use 4x100 bolt pattern and get correct size Centering rings to fit the wheels. MINI hub bore is 56.1mm.
Check also the weight of the wheel, usually 18" are quite heavy so it's more for appearance. 205/40-18 tire should be OK for handling and comfort, you can choose All Season or Summer tires.
Old Feb 5, 2008 | 04:47 PM
#20Works4me
Thanks for the reply, I was just a little concerned about the offset as I have 42mm on my current 18's lowered with Eibach's on 215/35/18's. The new Mini will be lowered less so with JCW suspension but a minimally larger diameter tire at 205/40's but the 45mm offset. Does that make the rim stick out more or less? thanks again.
PS I believe Kalbone 's wheels are 18"x7.5" with a 45mm offset and he has a major drop!
Old Feb 5, 2008 | 05:00 PM
Wake|MCS's Avatar
Wake|MCS
ET45 means your new wheels would be 3mm closer to your suspension, so it tucks inside more. Why not run a 5mm spacer, running an effective ET40 and go with 215/40/18 to fill more of the wheel gap since you'll have a good amount with the VERY mild JCW suspension.
Just a thought...
Old Feb 5, 2008 | 05:07 PM
PGT's Avatar
PGT
7.5ET45 is very tight. I ran 215/35/18's on PSS9's and now 215/45/17's on Cross and both are but mm's away.
Old Feb 5, 2008 | 07:57 PM
Wake|MCS's Avatar
Wake|MCS
Keep in mind the OP is going to run a 0.5" drop, nothing compared to what you're running lol. Don't scare him like that
Old Feb 5, 2008 | 08:00 PM
PGT's Avatar
PGT
I'm higher than stock at the moment.
Old Feb 6, 2008 | 08:48 AM
Wake|MCS's Avatar
Wake|MCS
Oh, haha. When you say mm away, do you mean from the suspension itself or from rubbing on the inner wheel liner?
Either way, I think the wheel would look better on the car with a 5-10mm spacer as an ET45 isn't quite flush with the fenders...
Old Feb 6, 2008 | 10:14 AM
PGT's Avatar
PGT
the lockrings on the lower perch. close, but not hitting.
Old Feb 6, 2008 | 10:31 AM
joshamman's Avatar
joshamman
I have motegi 18s (different style ) with 35 series tires and they fit/look great
Old Feb 6, 2008 | 11:51 AM
Wake|MCS's Avatar
Wake|MCS
Ah that's not likely to be an issue with the JCW suspension though...
Chibi2
May 19, 2016 03:46 PM
StrongIslandMini
Sep 16, 2015 12:58 AM
Tires, Wheels & Brakes
Sep 10, 2015 02:53 PM
