Big brake kits and wheels... updated list
Old Nov 3, 2007 | 05:39 AM
  #26
shooler's Avatar
shooler
TCE/Wilwood 14" kit with 18X7 OZ Ultralegerra (ET 42 requires no spacer)
altapics032.jpg?t=1194093559
Old Nov 3, 2007 | 07:01 AM
  #27
minimusprime's Avatar
minimusprime
thanks for the updates guys. I'm going out for bfast with the woman then I'll do some updating.
I think im going to add links to templates (when available) under each kit.
Old Nov 3, 2007 | 07:36 AM
  #28
MiniMacPR's Avatar
MiniMacPR
Nice thread
Not sure if its too early for a "sticky" status but you have my vote
Old Nov 3, 2007 | 03:51 PM
  #29
drmike@txwerks.com's Avatar
drmike@txwerks.com
Cool. Here's a link to the TSW BBK template:
http://www.txwerks.com/images/Instal...ILHOUETTE1.pdf
Old Nov 3, 2007 | 04:42 PM
  #30
PGT's Avatar
PGT
AP Racing template
Old Nov 4, 2007 | 06:12 PM
  #31
garylimey's Avatar
garylimey
I just installed on my GP the Stoptech BBK with 8mm spacers in order to stop the tires touching the thicker Strut of the M7 coilovers. The car is lowered with negative 2 camber front and rear, its real tight, lucky thing there's no back seats.
SSR type C RS 17x7.5 wheels with BF Goodrich g-force T/A KDW 215/45ZR17 tires. The wheel offset is 42
Old Nov 5, 2007 | 05:37 AM
  #32
minimusprime
Ok Folks updated. Sorry for the lack of updates over the weekend but we're all caught up.
Thanks for all the help.
Old Nov 5, 2007 | 06:09 AM
  #33
toddtce's Avatar
toddtce
This is a nicely compiled list but it may be a bit misleading in a way.
Without looking at the template needs for each kit and comparing them we're listing them by manufacture and not by clearance. That would lead one to believe there are less choices for one kit over another, or another.
What clears a Stoptech kit for example will clear either of the TCE13" kits. What clears a Wilwood factory 12.2" kit (TCE Plus 2) will most likely clear the Detroit Tuned. As well as all those wheels that cleared the Stoptechs.
Actually I created a huge spread sheet on all of this- and much more technical data, years ago. Not sure if I can find it or not but I'd suggest the list be populated by "caliper overhang". That way you'd see what space is needed for each kit rather than how someone made them work with spacers.
Also note that some templates include air gaps, others do not for cut out or fit purposes.
BTW: Wilwood factory templates
11.75- http://www.wilwood.com/PDF/ds492.pdf
12.2- http://www.wilwood.com/PDF/ds490.pdf
TCE- http://www.tceperformanceproducts.com/wheel_fit.html
Old Nov 5, 2007 | 06:34 AM
  #34
mbcoops's Avatar
mbcoops
Wilwood 11.75 fits over rota slipstreams 15x7 +40 with a 5mm spacer:
https://www.northamericanmotoring.co...d.php?t=118715
mb
Old Nov 5, 2007 | 06:37 AM
  #35
minimusprime
This is a huge concern of mine. A list like this is not only a huge undertaking but also a liability in several fashions. People may mistake the wheels listed as the only ones that will fit a certain kit... also just as you said the lack of responses may make people think that a certain kit has less fitment.
I'm not quite sure what to do about this... but I will tell you that as a consumer with a big brake kit... shopping for wheels is very very hard.
I guess I'll brain storm and come up with something. Maybe we could slide a post in under the main one that discusses profiles from caliper to caliper?
Old Nov 5, 2007 | 02:35 PM
  #36
toddtce's Avatar
toddtce
A thought here might be to list the "Big Brake Friendly" wheels on the market and list what spacer is required then for each BBK option. Kinda coming at it from the other side maybe?
I'm good with the idea and thought here, I just don't want folks to get the impression that one kit or another has limited wheel choices over the other due to lack of posts by customers or what spacer is needed. For example a ST kit with 8mm spacers may use the same wheel and no spacer with a DT kit or a 3mm spacer is needed on a Wilwood factory kit.
Personally I think (admitedly partially a business decision here) that you should list the caliper body over hang of each kit based on the templates or data supplied. Then list the normal spacing of common wheels used perhaps so someone can calculate the required spacer (or close) that they'll need for the wheel options.
So far you have brake kit sizing info for about ten kits I think so line them up on sizing order. Don't forget to add the Porsche kit, the Torax and any other lesser known kits also for equal air time.
Old Nov 5, 2007 | 03:50 PM
  #37
garylimey's Avatar
garylimey
Old Nov 6, 2007 | 12:20 AM
  #38
tomonline's Avatar
tomonline
hi - so i came with my first question - did actually someone fit the 16" X-lites on the wilwood 12.2 street-kit (probably with spacers?)
tom
Old Nov 6, 2007 | 11:30 AM
  #39
cct1's Avatar
cct1
Kosei K1 TS 1 15x7 clear JCW brakes (R53).
Old Nov 6, 2007 | 03:05 PM
  #40
garylimey's Avatar
garylimey
I tried 5mm spacers today instead of 8mm, it's close but no rubbing on the struts
Old Nov 8, 2007 | 07:50 AM
  #41
minimusprime
bump.
still looking for input from bbk owners.
Old Nov 19, 2007 | 11:18 AM
  #42
agranger's Avatar
agranger
Wilwood 11.5 kit:
16x6.5 Rota Slipstreams fit with a 12mm spacer - The 5mm spacers weren't enough (agranger)
Old Nov 25, 2007 | 03:10 PM
  #43
COR BLMY's Avatar
COR BLMY
Urban myth help or other options
I have the wilwood plus 3 and understand that an OZ ultralegga (sp ?) 16" will fit.??? IS THIS TRUE ?
I am after info on any 16" that may fit.
I do auto-x and a 215/40 16 is only 22.4" tall (8.5 tread width)
or a 234/40 17 is 24.2 tall (but 9.5 wide)
Cant really figure out if a tire that much shorter BUT 1' narrower is better ?:impatient
Old Nov 25, 2007 | 08:18 PM
  #44
Mini7's Avatar
Mini7
S-Lites & TCE Plus1 Wilwood BBK
Does anyone know if stock S-lites will clear the 11.75"x.81" TCE Wilwood kit?
If not what spacer would I need?
Old Nov 28, 2007 | 05:44 PM
  #45
Mr. Q's Avatar
Mr. Q
bump.
+1
Old Nov 28, 2007 | 06:38 PM
  #46
quikmni's Avatar
quikmni
Wilwood/TCE 13" Rotor with FSL Caliper under BBS RGR 17x7, 38 offset with no wheel spacer.
Old Nov 28, 2007 | 07:25 PM
  #47
toddtce's Avatar
toddtce
No kits clear this wheel that I'm aware of. Poor wheel design.
Old Nov 28, 2007 | 07:43 PM
  #48
PortMCS's Avatar
PortMCS
^ That sucks! I could see this posin a problem in the winter when i wanna switch over to the S-lites for the winter driving months
Old Nov 29, 2007 | 06:13 PM
  #49
agranger's Avatar
agranger
I just fit an S-lite tonight for another NAM-er, so here is my new post from above along with an additonal S-lite fitting:
Wilwood 11.5" rotor kit:
- 16x6.5 Rota Slipstreams fit with a 12mm spacer - The 5mm spacers weren't enough (agranger)
- S-Lites: Barely fit with a 5mm spacer, but 7-8mm STRONGLY recommended (agranger)
Old Dec 3, 2007 | 04:58 PM
  #50
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Great to see this being compiled! This will help in the future tremendously.
