Will Run flats work on aftermarket rims?
Old May 30, 2003 | 07:11 AM
friedduck's Avatar
friedduck
Met a guy last night at the Italian Job premier who was running run flats on konig rims. I thought that run flats had to be installed on special (rims designed for run flats) rims.
So what's the story? Would a light aftermarket wheel have any problems with run flats or does it vary wheel by wheel?
TIA, Jeff
ps: The Movie, and seeing a parking lot full of MINIs/Minis, rocked!
Old May 30, 2003 | 08:53 AM
Alex@tirerack's Avatar
Alex@tirerack
Its been sugested that the saftey humps on wheels designed for use with runflats may be larger. This would help in bead retention in zero pressure conditions. All wheels these days have saftey humps of 1 sort or another.
Alex
>>TIA, Jeff
Old Jun 3, 2003 | 09:02 PM
friedduck's Avatar
friedduck
Thanks Alex--forgot I'd posted this.
Jeff
Old Nov 29, 2004 | 09:27 AM
gr8britwjh's Avatar
gr8britwjh
So, is this a definitive yes..........if I wanted to use runflat tires on aftermarket (non-OEM) rims I would be OK........just don't question my sanity for wanting to do so
Old Nov 29, 2004 | 02:01 PM
SwingMCS03's Avatar
SwingMCS03
Yes you can use the run-flats on aftermarket wheels. Just make sure the place you go can handle the installation.
Old Nov 29, 2004 | 02:44 PM
gr8britwjh's Avatar
gr8britwjh
Thanks "Swing"...........man, the compromises you make for a happy marriage
Old Nov 30, 2004 | 05:21 PM
SwingMCS03's Avatar
SwingMCS03
It's not swingin'MCS03.
Colt45Magnus
Sep 7, 2015 10:47 PM
PrimePower
Aug 16, 2015 06:29 PM
sabjcw
Aug 14, 2015 07:40 AM
minipopkart
Aug 13, 2015 05:22 AM
