2005 Mini Cooper S Aero Kit & Challenge Wheels
2005 Mini R53: "Mk I" Mini Cooper S
  • 2005 Mini R53: "Mk I" Mini Cooper S - 2005 Mini Cooper S Aero Kit & Challenge Wheels - Used - VIN WMWRE3341TD92274 - 165,000 Miles - 4 cyl - 2WD - Manual - Hatchback - Silver - Glen Cove, NY 11542, United States
    $3,500
    • OBO
  • Location Glen Cove, NY, 11542, USA
  • VIN WMWRE3341TD92274
  • Mileage 165,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Silver
Dark Silver / Black
6 Spd
165,000 miles
Clutch was done in Jan 2019, 20k miles
205 45 17 General AS 05s (June 2020)
17% pulley with appropriate belt (Dec 2020)
BKR7EQUP Plugs (Dec 2020)
380cc Bosch Injectors (July 2023)
CAI w KN style cone filter (July 2023)
Adrian tune to 7200 rpm (July 2023)
Stainless Cat Back Exhaust with custom turbo resonator replacing secondary cat, nice sound - not too loud, mid 2019
The car had a refresh in Dec 2020, inner & outer tie rods, ball joints, etc all OE/Lemforder/Febi along with tensioner, water pump, PRW Crank Pulley & SC service. Valve cover gasket and various o rings/seals on the block were replaced. See image for totality of parts changed in Dec 2020 and shot under valve cover from then as well.
Solo Werks S1 Coils
23mm Rear Bar
Adjustable End Links F&R
Adjustable Rear Lower Control Arms
Strut Tower Plates
Brembo Drilled Rotors
Stainless Lines
EBC Green Front Pads
Powerflex everything, rear trailing arm bushings were not installed but will be included.
New battery (July 2024)
Belt tensioner strut & secondary 02 sensor (Aug 2024)
Will include R56 front brake calipers, carriers, braided lines, extra set of rear stock calipers and rebuild kits for both front & rear calipers. Set of stainless headers, stainless expansion tank, tstat & housing, oil pressure switch, new front & rear Mini emblems, various brand new mirror caps, black front honey comb grills, replacement A pillar moldings, OE hood scoop & rear tow hitch cover (both will need to be painted) and rear aero bumper decals.
The bad – it will need driveshafts and I’d probably do wheel hubs all around as they’re likely all original. The passenger seat is in poor shape. The driver side could easily be repaired (split at seat bottom seam) but passenger is likely beyond saving, the leather is hard, also split at seam, and I can’t get it to recline. Most recently, the hood latch was stuck closed. Latch was replaced but incorrectly, warning light shows on dash that it’s open and dash "brake" light constant on. Glove box needs to be replaced. Otherwise, everything works.
Pains me a bit typing this out as it took a while to find the aero kit & wheels but I think it’s time to let go here. The aero kit & wheels make up for half my asking price. I'm likely forgetting things, please feel free to DM.
$5800
Old Sep 10, 2024 | 03:45 PM
BMH94's Avatar
BMH94
Sharp car!
Old Oct 17, 2024 | 06:49 AM
daviday's Avatar
daviday
Bumping & updating price - $5000.
Old Dec 4, 2024 | 08:35 PM
daviday's Avatar
daviday
Bump.
Old Dec 5, 2024 | 03:17 PM
daviday's Avatar
daviday
Some new issues have developed with the car. Namely the hard brake lines will need to be replaced. They've corroded, it is leaking fluid and it is currently unsafe to drive. I'd like to get $3500 as is for the car along with everything mentioned.
Old Dec 9, 2024 | 09:39 AM
djmini420's Avatar
djmini420
Nice looking car. To bad you aren't in Cali. GLWS!
Old Dec 10, 2024 | 06:48 AM
daviday's Avatar
daviday
Thank you, I appreciate that. Needs a little love but everything is there for someone capable looking for a solid driver.
Old Dec 22, 2024 | 10:10 AM
Turbo R53's Avatar
Turbo R53
Is this car still available?
Edit: short answer…nope!
It’s in my driveway now…
…thank you daviday!
Old Jan 4, 2025 | 07:16 AM
daviday's Avatar
daviday
…thank you daviday!
Happy to see you made it back. My pleasure. Very good meeting you and your son!
Old Jan 4, 2025 | 02:45 PM
Turbo R53's Avatar
Turbo R53
Thank you…nice meeting you as well!
Parked next to his big (engine) brother…
