2005 R53 Mini Cooper S (LY/B)
2005 Mini R53: "Mk I" Mini Cooper S
  • 2005 Mini R53: "Mk I" Mini Cooper S - 2005 R53 Mini Cooper S (LY/B) - Used - VIN WMWRE33485TD94250 - 132,000 Miles - 4 cyl - 2WD - Manual - Hatchback - Yellow - Phoenix, AZ 85083, United States
    $1,250
  • Location Phoenix, AZ, 85083, USA
  • VIN WMWRE33485TD94250
  • Mileage 132,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Yellow
Sadly, it is time to let him go.
I am the original owner of this Mini, built him and watch him sail across the pond to South Carolina back in 2004.  I bought him out of San Antonio and had him trucked to Phoenix, AZ.  I had every intention of keeping him and putting him back together but life has thrown me a few curveballs and it is time to part ways.  Anyone that has followed my Mini thread knows the car is in great shape.  I would walk through what I did, what I replaced and cleaned up everything I came across along the way.
But a few months back, something bad happened that has left him idle in the garage.
NON-RUNNING
If I had to guess, it is a crank bearing in the block?  The last time I drove him, I limped him home.  At a stop light, I was getting a stutter at idle with the oil pressure light coming on the center dash.  Driving would be ok at higher RPMs but in the end that started to suffer and there was stuttering through the gears.
So I parked him and thought about what I wanted to do with him.  Replace the motor?  Or sell him to someone who would replace the motor and take care of him.
It is time to put him up for sale sadly.  I am not happy about this…
He has around 132,xxx miles on the chassis.  It has the original clutch that is still functional.  Flywheel was replaced back in April-2006 under warranty.  But it pains me to say that the clutch lasted longer than the motor.  Very frustrating.
THE BADs:
Motor is having issues with stumbling and oil pressure lights.
Air conditioning compressor does not work.
THE GOODs:
Chassis is in good shape I would say.  Front end has little chips here and there.  There may be 2-3 small indentations in the body where the paint is not affected.
Transmission (non-LSD) is in great shape.  Clutch is getting weaker but will be swapped when motor is repaired/replaced.
Power steering pump works great.  P/S lines were replace in my thread in Aug-2016 at 113.8k miles.
Radiator has been replaced in May of 2022.
All bulbs have been replaced except for the headlights.  Those are original.
PERFORMANCE ITEMS:
Milltek header and the Milltek catback exhaust.
Rogue Engineering air intake
Alta 15% pulley on the original supercharger
TIRES:
All 4 tires are Yoko Advan Sport A/S+ 215/45-17
All 4 tires have been replaced in April-2021 and only have approximately 4,600 miles on them.  Should be 10/32 of tread at all 4 corners.
Run-flats are gone and I carried a spare full size wheel in the trunk.
BRAKES:
Front brakes should be around 8mm left
Rear brakes should be around 7mm left
I upgraded the caliper bushings to steel so there is no flexing or mis-alignment with the brake pads.
Brake fluid test should yield 1% (maybe 2%) water in the brake fluid which is good.
Brake pad sensors are present but not connected.  I very much disliked the design using the sensor, let alone replacing the sensor at brake pad change intervals.  I checked/measured the brake pads every 6-12 months for when they got close to the limit and then just replaced the pads.
SUSPENSION:
Suspension is stock from 2005 at each corner.  Front top mounts are intact.
Swaybars are stock from 2005.
I have the stock cat-back exhaust system at the house that will go with the car.  I am sure I have a few spare parts here and there as well that will accompany the car.
That is all that comes to mind at the moment.  Feel free to asking questions.
Current pics?  He looks the same as he does in this thread.
MY MINI COOPER S THREAD
Price?  I was hoping to get $1,250 out of him given the condition and parts on him.  Lets see what kind of offers come in and then I will take the time to consider each.
Thanks,
Jeff
Old Mar 18, 2023 | 05:27 PM
MCS4FUN's Avatar
MCS4FUN
^^^ Despite the possibly damaged engine, IMO, price seems low for a from-new Arizona R53. With that and if accident-free (or nearly so), most dings or dents should be removable using a PDR (I've used a mobile pro based in that area twice). Right now, "fire sale" pricing for a quick sale. With more details and pictures outlining body and interior condition, perhaps ask and get more $$.
Good luck with your sale and hoping it (he?) goes to a new owner whom will enjoy and appreciate. BTW, greetings from Rim Country!
Old Mar 30, 2023 | 05:19 AM
Xplct's Avatar
Xplct
If only you were closer, I would buy it. Good luck, this should go fast.
Old Mar 30, 2023 | 02:47 PM
CooperSAZ's Avatar
CooperSAZ
Thanks Xplct. I just want him going to a good home.
Old Mar 31, 2023 | 04:44 PM
Here2Go's Avatar
Here2Go
NAM Community Team
That is a nice looking little guy you have there. Too bad you have to give "him" up.
Although, I'm really hoping to find an R55 (clubman), and If I wasn't so far away...
But before you decide to part ways - With regards to the fluctuating oil pressure - (your assessment (main bearing(s)) may be correct and is indicative of the symptoms you describe).
However, might I suggest you try one last ditch effort?
This little plunger in the oil filter housing may have failed....Take a look and see if it's broken.
Worn bearings may not be the issue?
@$30 = Inexpensive and may be worth a shot?
Out Motoring - Oil Filter Housing Drain Plunger
Very tempting asking price for your Mini.
Although I hate to think you had to give him up if turned out to be a simple fix after all.
Just a thought.
Best regards.
Old Apr 3, 2023 | 10:31 AM
CooperSAZ's Avatar
CooperSAZ
Just a thought.
Best regards.
Thanks Here2Go, I will look into this and nose around.
Old Apr 6, 2023 | 01:37 PM
CooperSAZ's Avatar
CooperSAZ
Bumping the thread.
Down to a little time left before he gets donated to a charity.
Old Apr 6, 2023 | 01:45 PM
djmini420's Avatar
djmini420
To bad this car wasn't in Cali. Any pictures on the interior?
Old Apr 7, 2023 | 04:15 PM
CooperSAZ's Avatar
CooperSAZ
Interior shots.
Driver side seat has a torn bolster side.
Old Apr 7, 2023 | 05:38 PM
djmini420's Avatar
djmini420
Interior looks good. I wouldn't give it up try and fix it
Old Apr 10, 2023 | 06:21 AM
henc's Avatar
henc
PM'd you.
Old Apr 10, 2023 | 11:11 AM
CooperSAZ's Avatar
CooperSAZ
Responded to you henc.
SALE IS PENDING.
Old Apr 15, 2023 | 07:34 PM
CooperSAZ's Avatar
CooperSAZ
sold.
