Suspension IE adj. camber plate Question
Old Mar 12, 2007 | 08:50 AM
CRRIKEY's Avatar
CRRIKEY
I just got the IE adjustable camber plates. (Which came with no instructions ) They came with three 3/16 ish spacers per plate. i didnt see a need for too much offset, so i put one spacer on, then the camber plate, then another space for a washer, then the main nut on. Before i put these under my car, does anyone know how many spacers i should be using
Old Mar 12, 2007 | 10:41 AM
txwerks's Avatar
txwerks
Ireland ships the three compliance spacers for different struts/coilover setups... To date, we've only ever had to use two - one between the upper spring perch and spherical bearing assembly, and one on top of the spherical bearing under the strut's top nut. This has always allowed plenty of movement with OEM style springs and on our Ledas, but Ireland has told us that other setups may require the use of two compliance spacers under the spherical bearing.
As long as the spherical bearing can rotate and move freely, you should be fine... It's important to use the right stack height so you get plenty of threads to spin the nut on, as well as providing enough freedom for the spherical bearing assembly...
I'm not sure why directions stopped shipping (although, they could have been a bit more explicit, anyhoo). We'll send a note to Ireland...
Old Mar 12, 2007 | 02:22 PM
CRRIKEY's Avatar
CRRIKEY
Thants exactly the information i was looking for. Thanks a bunch, a great help. I also wrote them a letter saying that i would take pictures and do a write up if they needed it.
Hippiehobbit267
Dec 3, 2019 04:22 PM
WestfaliaR
Aug 19, 2015 08:01 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
