Suspension H&R 19mm questions
Old Mar 8, 2007 | 07:59 AM
nypepper's Avatar
nypepper
H&R 19mm questions
i just got a H&R 19mm bar and it came as just the bar and bushings
is this normal
does this bar reuse the factory bushing supports ?
Old Mar 8, 2007 | 08:03 AM
mbcoops's Avatar
mbcoops
I thought this was odd, too, when I won one. I'm having it installed next week; I guess I'll know then if I need more hardware.
mb
Old Mar 8, 2007 | 08:10 AM
nypepper's Avatar
nypepper
i order a set of factory supports because i did my alta bar install at a garage party and forgot to collect my stock parts
the bushings look like they fit i just want to be sure before i pull my car apart
Old Mar 8, 2007 | 09:03 AM
thulchatt's Avatar
thulchatt
is this normal
Yes, just pull the factory bushings out of the fitting and press the H&R in their place. Very easy fit.
Good choice, I have had the H&R on for about a year and no noise yet.
Old Mar 11, 2007 | 09:00 AM
blammo's Avatar
blammo
Did you use grease when installing the bar? I've read that H&R has some special bushings that don't require it... I"m planning to get one soon (to replace my squeaking Alta), and am wondering whether it should be greased (just to be safe) or not... Thanks.
Old Mar 12, 2007 | 06:37 AM
thulchatt's Avatar
thulchatt
I did not grease the bushings. The directions I got said it was not necessary so I did not.
Old Mar 12, 2007 | 06:42 AM
mbcoops's Avatar
mbcoops
I think the whole point of the bushings is to not (or not have to) grease them. I'm far from an expert, however.
mb
donniedarko
Oct 21, 2015 01:15 PM
PSU 98
Sep 11, 2015 11:20 AM
cinnabun
Sep 11, 2015 05:55 AM
marc0011
Sep 10, 2015 10:04 PM
Robree
Sep 9, 2015 08:43 AM
