Suspension Texas Speedwerks Springs... launch!
Old Dec 4, 2006 | 07:32 PM
  #76
chuckt's Avatar
chuckt
Thanks guys.
Old Dec 5, 2006 | 07:33 AM
  #77
agranger's Avatar
agranger
It took about 75 miles or so before my ride height stabilized. I got about 2/3 of the drop w/ the install and another 1/3 or so after the 75 miles.
Old Jan 10, 2007 | 04:25 PM
  #78
PGT's Avatar
PGT
bump for more end user feedback
Old Jan 12, 2007 | 08:07 PM
  #79
70spop's Avatar
70spop
Vedy interesting, all this! Question(s):
I've got a late '03 S (heavy rake and pre-factory-rear-camber-adjustment) with a sunroof. I had the JCW suspension installed last spring. I'm REALLY happy with the handling, the ride quality is ok (firmer than stock S, but not necessarily harsher), and the front drop is perfect (I've got mushrooming, so I'm probably a slight bit lower than the factory claimed .4"). Part of the reason I went with the JCW was for the moderate drop - I had a slammed Civic before my MINI, and didn't want to repeat that experience - just get it down around the tires and tighten up the handling (the Civic DID look bitchin' with the race springs, but I digress).
HOWEVER, I was hoping the rear would come down a bit more than it did. Those early Ss are too jacked up in back. The JCW lowered the rear a bit, but it's still higher than most STOCK '04-'06 Ss that I see.
Will the TSW springs help out with bringing the '03 rear end down a bit more? Or is the giant rake caused by something else with the early suspension? agranger's car looks like a newer one than mine, but I'd like my car's rear to sit about the same height. You state that the TSW springs work well with the stock struts. Have you tested them with the JCW struts?
Would I be shelling out cash for a negligable change swapping the JCWs for the TSWs?
Old Jan 13, 2007 | 03:43 AM
  #80
cajun's Avatar
cajun
I droped my LilRed the other day. The TSW springs are great. Not to harsh on the ride and tightens the MINI up just right for me. Here are some befor and after picts.
and this was right after Install, so there is alittle more drop but not much.
Old Jan 13, 2007 | 06:03 AM
  #81
S Curvz's Avatar
S Curvz
^ what size tires, looks great! Keep us updated on drop
Old Jan 13, 2007 | 08:39 AM
  #82
txwerks's Avatar
txwerks
The front will settle in a bit over the next couple hundred miles... glad you like them!
Old Jan 13, 2007 | 12:11 PM
  #83
cajun's Avatar
cajun
my street tires I run 195/60/15. My race tires I run 205/50/15
Old Jan 14, 2007 | 12:34 PM
  #84
txwerks's Avatar
txwerks
As I responded via PM, we have not tested our springs with the JCW struts - however, the plot on the JCW units is not a whole lot different than the SS+ units that we have tested the springs with... I think our springs would offer you exactly what you're looking for...
Old Jan 14, 2007 | 05:14 PM
  #85
70spop's Avatar
70spop
Ordered! I'll update after they've been installed and driven a bit.
Old Mar 2, 2007 | 05:54 PM
  #86
ScottinBend's Avatar
ScottinBend
I just checked your site and I notice the springs are no longer listed. Why is that?
Old Mar 2, 2007 | 07:55 PM
  #87
txwerks's Avatar
txwerks
We're sold out at the moment... The next run is in process and on the way!
Old Mar 3, 2007 | 08:30 AM
  #88
txwerks's Avatar
txwerks
ETA on the next run is 3 weeks...
Old Mar 3, 2007 | 02:06 PM
  #89
discodan's Avatar
discodan
anyone running these springs with the Bilstein SP's? how do they like them? compared to any other combo, stiffer, more compliant,etc.? thanks
Old Mar 3, 2007 | 08:28 PM
  #90
minimarks's Avatar
minimarks
Can I get them with the same drop front and rear?
Old Mar 7, 2007 | 01:03 PM
  #91
jsound's Avatar
jsound
Originally Posted by txwerks
3. Increase in spring rate over OEM - why? We've take 3/4" (average) of travel away, so we want a slightly higher spring rate to compensate for the loss in height. And, the OEM springs are NOT well matched to the OEM shocks/struts. In our testing, the OEM shocks/struts need a slightly higher spring rate - they have too much bound/rebound. Our springs match well with virtually any strut. They ride better with the OEM shocks/struts than any other spring on the market - period. We've been on all of them and they all have some disadvantage - we evened everything out, and ended up with a superior compromise in asthetics and performance.
Anyone here know why the OEM springs would not match well with the OEM shocks/struts? Is it a safety concern like how the MINI Coopers come stock with understeer or some other reason? I can't make sense as to why MINI would complete a vehicle with subpar settings.
Old Apr 24, 2007 | 07:59 AM
  #92
HAVNPHUN's Avatar
HAVNPHUN
Is there any new feedback on the TSW springs with FSDs?
Old Apr 24, 2007 | 08:04 AM
  #93
cajun's Avatar
cajun
I'm running the TSW with the FSD's and love em. I even Auto-X with them and they do just fine for me. the ride is Realy smooth with 17s on.
Old Apr 24, 2007 | 09:05 AM
  #94
HAVNPHUN's Avatar
HAVNPHUN
Thanks for the feedback Cajun. Any problems with bumpstopping on rough roads? Did you modify your stock bumpstops or use shorter ones?
Old Apr 24, 2007 | 09:17 AM
  #95
04SDmini's Avatar
04SDmini
Ditto. I have the same set up FSDs and TSW springs, with IE fixed camber plates up front and adjustable rear control arms in the back. A HUGE improvement over stock handling and a more comfortable less abusive ride
Old Apr 24, 2007 | 10:53 AM
  #96
cajun's Avatar
cajun
I had to cut the bottem part of the bumpstops off. But never had any problems at all with them. I'm also running The H-sport lower control arms, and they do help also.
Old Jun 1, 2007 | 06:01 AM
  #97
chuckt's Avatar
chuckt
Are there any vendors for these outside of Texas?
Old Jun 1, 2007 | 08:03 AM
  #98
HAVNPHUN's Avatar
HAVNPHUN
Observed ride height
What was your ride height after the FSD/TSW/IE plate install?
I just went with this combo on my cabrio and have noticed a .5" drop in the back, but a 3/8" INCREASE up front. Based on what I've read, I'm assuming this will drop more as the bushings on the IEs settle. But I wasn't expecting a gain with this setup since the TSW springs are lowering springs (albeit a modest drop).
Old Jun 1, 2007 | 08:18 AM
  #99
chuckt's Avatar
chuckt
...a 3/8" INCREASE up front....
Ouch... That's not what I wanted to hear!
Old Jun 2, 2007 | 08:32 AM
  #100
04SDmini's Avatar
04SDmini
After settling in I'm riding about 3/4" lower in the front and 1/2" lower in the back.... Never saw any increase though... I would have expected the cabrio to ride a bit lower just due to the added weight.
