Suspension looking to install coilovers this weekend - need some torque #'s
As the title says, what are the torque specs of the following bolts -
18mm pinch bolt (secures strut to hub carrier)
13mm strut tower bolts (front and back)
single bolt ontop of strut/spring assembly
thanks!
thanks!
Sorry they took awhile. Been busy.
Rear Strut lower mount to trailing arm: 140nM(103 ft-lb)
Rear strut upper mount to strut tower: 56nM (41 ft-lb)
Rear strut center retaining nut: 30nM (22 ft-lb)
Front strut upper mount to strut tower: 34nM (25 ft-lb)
Front strut to steering knuckle pinch bolt: 81nM (60 ft-lb)
Front center sturt retaining nut: 64nM (47 ft-lb)
Hope this helps.
Hope this helps.
squawSkiBum
Oct 2, 2015 09:21 AM
minipopkart
Aug 13, 2015 05:22 AM
