Suspension Rear trailing arm bushing inserts installed
SuspensionSprings, struts, coilovers, sway-bars, camber plates, and all other modifications to suspension components for Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Great! Thanks!
I'll have the rear shocks off to reset the adjustment anyway. (Koni Yellows)
Do I tighten the large bolt with the suspension loaded?
Jim
Yes. I have always read that the rule of thumb is; bushings are loaded and metal to metal is not. Good luck.
I'm surprised this thread was never stickied. Lots of good info here although the links to TonyB's pics no longer work. I'm about to tackle the front and rear bushings on my '05 MCS and this thread plus this one should make it a bit easier.
Anyone know what type of grease 'should' be used on these bushing inserts - silicon-based, white lithium, moly? The RTAB kits don't come with any and the poly alongside the OEM rubber bushings can't possibly be quiet without some lubrication. Perhaps anti-sieze would be a better choice.
Mine are still sitting on my bench. I managed to get the front PowerFlex bushings installed at local dealer-hosted DIY day, but haven't tackled the rears yet. I'd like to get them on before my first DE or AX event this season and if I do I'll try remember to document the installation.
