Suspension Has anyone tried the Megan Racing Coilovers?
Old Feb 28, 2006 | 06:05 PM
  #126
meb's Avatar
meb
Yes! The upper rates available are at the limit of public road comfort, but are also, in my opinion, too light for pure track work.
Tell us about your track only units...
Originally Posted by Megan Racing
We have Track Series for three of our cars so far. The S2K, S13, and S14. The track series is basically the same suspension system except with higher spring rates and more aggressive valving of the dampers.
We've been debating whether or not to have this for the Mini Cooper because it is a heavily tracked car. Do you guys think it would be a good idea to sell this? Lemme know.
Old Feb 28, 2006 | 06:18 PM
  #127
Megan Racing's Avatar
Megan Racing
Vendor
We can get as high as 14kg, so what combination would you be looking for?
Old Feb 28, 2006 | 06:49 PM
  #128
Thameth's Avatar
Thameth
$50.00 more for the Track Series so far on all other cars. I wouldn't mark you guys up just cause the Mini is made by BMW.
Thank gawd!
Old Mar 1, 2006 | 06:28 AM
  #129
meb's Avatar
meb
I'll know in a couple of weeks Megan. I need to perform a few more calculations.
Old Mar 1, 2006 | 09:12 AM
  #130
Megan Racing
Vendor
I'll never get used to being called "Megan"....
Old Mar 1, 2006 | 09:23 AM
  #131
FlynHawaiian's Avatar
FlynHawaiian
well give us a name to call you :D. redo your name to be joedoe@megan racing
:D
  #132
meb's Avatar
meb
...a name perhaps...
Old Mar 1, 2006 | 10:40 AM
  #133
Megan Racing
Vendor
Well my name is Steve... but there are a few hundred of us running around this forum, so that gets confusing.
Old Mar 1, 2006 | 10:45 AM
  #134
FlynHawaiian
how about redoing your user name to steve@megan racing? Might make it easier :D
Old Mar 1, 2006 | 10:50 AM
  #135
Megan Racing
Vendor
I dunno.. I guess I'll have to live with Megan for now.
Old Mar 1, 2006 | 02:44 PM
  #136
Dr Obnxs's Avatar
Dr Obnxs
Megan sounds way hotter!
Matt
Old Mar 1, 2006 | 02:46 PM
  #137
dave's Avatar
dave
pug poo picker-upper
PM if you'd like your username changed. It's pretty painless.
Old Mar 1, 2006 | 02:47 PM
  #138
Megan Racing
Vendor
It makes me feel beautiful... I dunno.
Old Mar 2, 2006 | 12:56 PM
  #139
Megan Racing
Vendor
Other Thread...
Hey guys, help me out here...
https://www.northamericanmotoring.co...610#post843610
Sway Bar?!
Old Mar 3, 2006 | 09:23 AM
  #140
ChocolateAZ's Avatar
ChocolateAZ
Hey Steve, this is mostly for you but anyone else feel free to chime in.
I just put on the coilovers, and I was eyeing the rear bushings on the top mount. I know that Madness is selling the polyurathane bushings.
http://www.mini-madness.com/index.as...ROD&ProdID=260
Would they be a good purchase for the top in back or should I stick with the OEM bushings?
Old Mar 3, 2006 | 09:43 AM
  #141
Scooby03's Avatar
Scooby03
Just to chime in. I think SRTech ordered ours from Webb Motorsports. I will know more tomorrow when we change out the top plates.
Old Mar 3, 2006 | 09:49 AM
  #142
meb's Avatar
meb
Sway Bar?!
Personaly, I would prefer a slider adjusting bar with a rate range somewhere between 17mm and 21mm. But, the bar should a be very light, hollow. I know, the heat treating process will make it expensive.
For my taste this is more useful on the street. I'll only be on the track a dozen times a year at most...zero autoXing.
Old Mar 20, 2006 | 12:36 AM
  #143
crazyaboutmini's Avatar
crazyaboutmini
update?
any updates on megan products so far? adding those pillowmounts into the coilovers? or how about the sway bar?
Old Mar 20, 2006 | 10:46 AM
  #144
Megan Racing
Vendor
Sway Bar is going into production this week. 25mm (Hollow) 5-Hole setup
We're going through construction options with the pillowball mounts but should see a prototype soon.
Old Mar 20, 2006 | 12:29 PM
  #145
haulinS's Avatar
haulinS
5 holes..........that's unprecedented!! I think...
Old Mar 20, 2006 | 01:01 PM
  #146
Megan Racing
Vendor
Nice-Proper use of the word. I figured it would give us the adjustability range of a Slider, but with an easier to install-setup process.
I'll let you guys know when they're protoyped and good to go.
Old Mar 21, 2006 | 12:46 AM
  #147
crazyaboutmini
thanks for the update can't wait to see the products.
Old Mar 28, 2006 | 10:57 AM
  #148
kurvhugr's Avatar
kurvhugr
I'm in the works of making extended adjustment ***** with a flexible line so that you can poke them through the interior and bolt them on to your interior and have the line going down to the top of the damper. That way all you'd see would be these two ***** comin outta the back.
I really hope these are in the works. I have the holes drilled but it's not easy to get my big hands in there to make adjustments. I'm definitely willing to punch a small hole through the interior plastic to mount an easily accessible adjustment ****.
Old Mar 28, 2006 | 11:09 AM
  #149
Scooby03's Avatar
Scooby03
The coilovers worked very nice this weekend. Put them to the test on the way back from AMVIV. The new swaybar that was put on also helped.
Very impressed with the Megan Racing Coilovers.
Old Mar 28, 2006 | 11:10 AM
  #150
Megan Racing
Vendor
Yeah, I'm going through with these. I'm using the same type of construction as the old speed cables on cars. But only 8" long so there's no chance of binding.
