Suspension Ireland Engineering "Fixed" Camber plates?
Old Feb 9, 2006 | 06:22 AM
  #51
oldschool's Avatar
oldschool
Sounds like the perfect setup for my car.
Thanks again!
Old Feb 16, 2006 | 06:52 AM
  #52
oldschool's Avatar
oldschool
Ride height ...
I'm installing these tonight and will take pictures with measurements from the ground to the fender before and after with the coilover perch set to the same height.
Then we can see if the 3/16 increase is offset by the negative camber ... which in my case will probably be around -2 degrees as I have the car set around 24.5" from the ground to the fender lip.
Old Feb 17, 2006 | 08:28 AM
  #53
Wesport's Avatar
Wesport
Great - Please comment on install ease (or not) and ride quality change also.
  #54
Wesport's Avatar
Wesport
Wes
Old Feb 17, 2006 | 09:12 AM
  #55
Morefun's Avatar
Morefun
Wes
If you can pull the struts and compress the springs (I use 3 $4 rachet straps from Walmart), then you can do the install. It's a no brainer. There is NO change in ride quality. My car is my daily driver and has had two winters with with the plates, snow tires and no issues. The Ireland fixed plates are the answer for most of the posters on this board who actually spend little or no time on the track or autocross course.
Cheers,
Old Feb 28, 2006 | 07:23 AM
  #56
oldschool's Avatar
oldschool
fixed plates ...
... I love them. Much more grip mid turn. I actually found that at my ride height the extra negative camber basically made up for the 3/16 plate. With my coilover perches set the exact same place, I measured the same ride height---24.5 from the ground to the lip of the front fender.
Not sure how much negative camber I have, alignment coming soon and I'll post the specs.
In my opinion, these are perfect for a daily driven car. More negative camber, without any added noise or harshness.
Old Apr 21, 2006 | 06:31 PM
  #57
jimz68's Avatar
jimz68
I'm planning on installing a set of these tomorrow. I already have H-Sport springs, so no need to compress springs.
Question, Is there enough room to be able to remove the 3 top nuts and pivot the strut out of the wheel well without removing the strut completely?
Thanks,
Jim
Old Apr 21, 2006 | 06:35 PM
  #58
MSFITOY's Avatar
MSFITOY
Thanks,
Jim
Fraid not...you must remove the entire strut from the MINI
Old Jun 12, 2006 | 12:46 PM
  #59
matma92ser's Avatar
matma92ser
Jim - Did you put these on yet? How do you like them?
Old Jun 12, 2006 | 08:20 PM
  #60
jimz68's Avatar
jimz68
Yeah! Installed a couple weeks ago. The extra negative front camber really makes the car turn in much quicker. Lot more stable under hard braking,too.
Jim
Old Aug 28, 2006 | 10:40 AM
  #61
waldvogelmj's Avatar
waldvogelmj
Has anyone that installed these taken their car to an alignment shop to see how much negative camber they create?
Old Aug 28, 2006 | 12:07 PM
  #62
Wesport's Avatar
Wesport
Mine give 1.5 degrees neg on stock springs with Koni FSD shock on an 03 MCS. This works very well as a street track comprimise.
Wes
Old Aug 28, 2006 | 06:43 PM
  #63
sprp85's Avatar
sprp85
So would you guys recommend these for a coil-over setup? will it depend on the ride height?
Plus,
If i 'm on stock suspension setup and planning to go coil-over in near future, should I get those anyways?
Old Aug 28, 2006 | 07:02 PM
  #64
Wesport's Avatar
Wesport
The lower your setup the more negative camber you will gain.
Wes
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
