Suspension Mild vibration with recent spring change
Old Apr 6, 2006 | 06:54 AM
  #26
fj0's Avatar
fj0
I know there is a solution, I'm sure of it! I just need to find it.
Old Apr 6, 2006 | 07:38 AM
  #27
meb's Avatar
meb
Well, for now, I'm just going to drive the **** out of the car at the track. If it breaks, I've found it. I've spent an intense 10 days looking for it. Everything is torqued correctly, installed correctly - all new nuts and bolts. Dunno???
Old Apr 6, 2006 | 07:41 AM
  #28
MiniS47's Avatar
MiniS47
Originally Posted by meb
I added to another thread about this. I installed Megans. The vibration eminates from the passenger side under acceleration in any gear; it is most pronounced in the lower gears as one might expect. The car is 3/4" lower than stock. I set the dampers at full hard to full soft. The vibration becomes very faint at full soft and very apparent at full hard - the Megans have a mono-ball upper front mount, so some grainyness gets into the steering anyway.
I've got about 600 miles on the set up and the vibration is not going away. I was extremely carefull with the axles and CV joints during the install.
So, I've no idea, but this appears to be a random, albeit, an obvious condition.
I have the Megans as well. Measured from the centerline of the hub to the lower edge of the plastic wheel arch trim, the front is 13 inches and the rear is 12.5 inches. If I go any lower up front I start to get the vibration (regardless of the damping rate or camber).
Old Apr 6, 2006 | 09:03 AM
  #29
meb's Avatar
meb
MiniS47,
What is your fender to wheel gap? Or better yet, jack point to ground. The front fender position may not be identical car to car since it is also the bonnet - a potential variable.
Old Apr 6, 2006 | 09:13 AM
  #30
fj0's Avatar
fj0
Here is mine
Old Apr 6, 2006 | 09:18 AM
  #31
MiniS47's Avatar
MiniS47
MiniS47,
Yep, that's the fender to wheel centerline. Jack pad to ground is 4 and 3/4 inches at the front. The rear is 5 and 5/16. My car is an 03' in case Mini has ever altered the jack pads.
Old Apr 6, 2006 | 10:09 AM
  #32
MiniS47's Avatar
MiniS47
Originally Posted by fj0
Here is mine
Lookin' good. I love the painted trim.
Here's mine. Only side view pic I have handy...
Old Apr 6, 2006 | 10:23 AM
  #33
fj0's Avatar
fj0
Looking good.
Stupid shaking! I want to drop it lower.
Old Apr 6, 2006 | 10:54 AM
  #34
BLIZZ's Avatar
BLIZZ
Now this is a man I can relate too.
You guys are making me feel better though, because after lowering my car with Koni Yellows & springs and the install of the Helix/RDR camber plates the front of my car was higher than the back by the same amount you mentioned is needed to not have a vibration {which I don't}. I was very dissapointed and was trying to figure out how to lower the front {for looks}, but now I think I will just leave it.
maestro39
Oct 27, 2015 02:38 PM
sprp85
Aug 22, 2015 06:16 AM
polotska
Aug 21, 2015 11:55 AM
FLYM1N1
Aug 16, 2015 01:17 PM
Fizzyx
Aug 14, 2015 08:24 PM
