Suspension rear subframe bolts
Old Nov 26, 2021 | 09:33 AM
Mr Meowgi's Avatar
Mr Meowgi
Cool rear subframe bolts
2015 mcs 4 door. swapping the rear sway bar. have found a few threads about it but no information on the subframe bolts themselves. if im looking at the correct bolts mine are a torx bolt. does that sound correct? cant find any info on that itself. everything ive read says 13mm so i thought i may be looking at the wrong bolts. but it looks that i need extension to reach the outer subframe bolts with the impact gun. but then can you even use an impact with torx sockets? really starting to change my mind with this one. any help i greatly appreciated
Old Nov 26, 2021 | 09:59 AM
TVPostSound's Avatar
TVPostSound
Yes, they are TORX, There are 4 fairly long.
NO DO NOT use an impact, they will round off.
Use an impact rated torx, a 1/2" extension with a 1/2" breaker bar. They are tight.
When replacing use the bolt washer marks to realign the subframe, or your toe will be out of whack.
Its not hard at all.
Newtis has the wrong picture, sorry.
Ill upload the right pic soon
Old Nov 26, 2021 | 10:08 AM
Mr Meowgi's Avatar
Mr Meowgi
Originally Posted by TVPostSound
Yes, they are TORX,
OK thank you very much. These straight forward jobs get me sometimes. I can only find one video of an f55/56 install and they completely skipped over that part of the video.
​​​​All rseries videos they were using impact guns. I'm pretty sure I have the correct ones in sight.
Just never thought I'd see so many torx bolts in my life. Ha ha.
Just been a rough one with this car for me.
Thank you for your help
Old Nov 26, 2021 | 10:11 AM
TVPostSound
I personally would not use an impact to break a torx that size free.
Old Nov 26, 2021 | 10:27 AM
TVPostSound
Heres a great DIY from NM engineering
They specify socket sizes, I dont recommend using the SAE (US) sizes, use the recommended TORX
https://cdn.shopify.com/s/files/1/02...847_44.pdf?259
Old Nov 26, 2021 | 10:35 AM
Mr Meowgi's Avatar
Mr Meowgi
I wouldn't have thought it would work out either. I can see it shearing off into another issue all together. I'm just not holding my mouth right I guess. Thank you for your help.
Old Nov 26, 2021 | 10:49 AM
TVPostSound
Im speaking from experience!!! The torx heads round off if the socket doesnt bite right and you impact.
Even if you get them out, you won't be able to retighten them the proper torque of 85 ft lbs
I had to buy a new set of bolts!!
Get a set of the non-chrome plated E-Torx
Amazon Amazon
The socket and extension must be straight on the bolt.
@ will be accessible from underneath, the 2 outer from outside when wheels are off
Old Nov 26, 2021 | 10:55 AM
TVPostSound
Did you ever buy that VIP bar?
Old Nov 26, 2021 | 04:36 PM
Mr Meowgi's Avatar
Mr Meowgi
Alright. Thanks everyone. Was able to get everything going this time. @Ghstrdr sent me a message and linked the NM pdf for me as well.
Im definitely grateful for everones knowledge here.
I have one more sub bolt to loosen up and ill be at the home stretch. Then onto an evap leak.
Thanks again for the help and quucj responses
toyopet
Tires, Wheels, & Brakes
May 10, 2016 07:47 AM
massmini03
Feb 13, 2016 02:47 PM
isteedman
Dec 23, 2013 05:14 PM
JTOR53
Mar 8, 2013 05:07 AM
brgfan
May 1, 2005 03:07 PM
