Suspension Recommendation for Rear Yellow Koni Settings Stock Springs
What is a good balance for the rear? 2013 JCW stock springs with stock sway. The fronts are easily adjustable, however the back are the pain to adjust once installed.
Car will be both an autocross and occasional street driving.
I was thinking just set it at 50% stiffness.
Thoughts? Experiences?
M
M
M
M
That would be great.!
I think there two styles, a hollow and solid bar. Is that correct?
Also, the top mount on the rear shock will not slip over the shock. It looks like i need to make the hole bigger. Is that normal?
M
M
It took me a little bit. Glad I did not erase the text of a friend that I helped him set up his mini. Hotchkis 22810r its 25mm. I also found where I told him 1 turn off of full stiff on rear koni's. That will probably be a better setting as he has never complained about handling. If your concerned about being a little stiff 1/2 will be adequate. Are you on sport springs or JCW springs (they are red)?
yes the bushing on the rear upper mount has to be drilled larger. The metal sleeve will slide out of the bushings to make it easier. That whole upper mount comes apart. I'm not 100 percent sure on the solid vs hollow but it seems like they had a 25mm hollow one for the older mini and they don't make anymore.
Montana Miniac
SCCA Solo and ProSolo
Jul 21, 2006 07:23 PM
