Suspension GP Style Rear Trailing Arm Conversion
Old Nov 17, 2020 | 05:16 PM
  #26
jk6672's Avatar
jk6672
Thanks guys. I just wrenched it, but it’s customer service like what Way provides which really make projects like this to go smoothly and easily.
Old Mar 31, 2021 | 03:28 PM
  #27
Kitchenboy's Avatar
Kitchenboy
I am going to do this swap as soon as the weather gets warmer. The set I bought came complete with only 8 loose bolts. I'm assuming the 6 that match are where the bushing mount bolts to the car and the other 2 are the shock bolts. I was going to buy new bolts but it sounds like if I'm careful the stock bolts should work fine. Also is there any real need to change the bushing to a power flex or just stick with the stock ones that are in there. Thanks for any info.
Old Mar 31, 2021 | 09:42 PM
  #28
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The aluminum arms use different bolts as they are all longer, and/or have nuts depending on which one it is. So it's very important to get all the bolts as we have seen the arm really cheap, but no hardware. And if you ever price out all the hardware it's a few hundred dollars just for nuts and bolts. We always make sure to include it all with our kits.
You will also need our shock adapters.
https://www.waymotorworks.com/wmw-re...k-spacers.html
We do recommend going ahead and upgrading to powerflex as it is much easier now than later. Plus the powerflex have a little more movement so it's easier to adjust. And you need the R56 ones now too.
https://www.waymotorworks.com/powerf...7-r58-r59.html
Old Apr 1, 2021 | 05:18 AM
  #29
Kitchenboy's Avatar
Kitchenboy
They came with all the original nuts and bolts. I just wasn't sure if it's ok to reuse the old hardware. I did order new shock bolts from your site. As far as the bushings from what I've read a lot of people dont like the power flex on the trailing arms because of how much stiffer they are than oem and put extra stress on the aluminum arm. I guess it's a personal preference. Thanks for the input Way.
Old Apr 1, 2021 | 05:29 AM
  #30
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I would do the PowerFlex trailing arm inserts:
https://www.waymotorworks.com/powerf...g-inserts.html
Old Apr 1, 2021 | 05:56 AM
  #31
Kitchenboy's Avatar
Kitchenboy
So those dont replace the bushings they go on top of the oem bushings. Is there any special tool I need or do they just get sandwiched in there. Thanks
Old Apr 1, 2021 | 06:00 AM
  #32
njaremka's Avatar
njaremka
Alliance Member
Community Builder
They sandwich the OEM bushing. No special tool needed. Take the bolt out and reassemble.
Old Apr 2, 2021 | 07:56 AM
  #33
WayMotorWorks
Vendor
Yes these powerflex bushings
are just inserts that support the stock bushing. Very easy to install as you just have to remove the bolt and install them like a washer on each side of the bushing.
Old Apr 7, 2021 | 01:57 PM
  #34
Kitchenboy's Avatar
Kitchenboy
Can they be installed before I install the trailing arms.
Old Apr 8, 2021 | 02:07 AM
  #35
JKo's Avatar
JKo
I've been told that the powerflex rear trailing arm bushes cause binding in the arm movement, and should be avoided because of that... any truth to that?
Old Apr 8, 2021 | 05:46 AM
  #36
Kitchenboy's Avatar
Kitchenboy
I trust what Way says. Hes been working on minis for years now. So I installed them yesterday. I've read the full bushing is to stiff but all these do is help support movement in the stock bushing. So we'll see.
Old Apr 8, 2021 | 07:17 AM
  #37
NoBars's Avatar
NoBars
I just bought the full bushing, from Way. I doubt that I'll feel a difference...
Old Apr 8, 2021 | 07:26 AM
  #38
Kitchenboy's Avatar
Kitchenboy
I was,afraid to go with the full bushing on the aluminum arm. I didn't want to put that much force on it.
Old Apr 8, 2021 | 07:46 AM
  #39
NoBars's Avatar
NoBars
LOL, thanks for the added paranoia...
The bushing is for an R56, so I'd have to think its safe
Old Apr 8, 2021 | 11:50 AM
  #40
jjcsnlynn's Avatar
jjcsnlynn
The PF directions tell you to torque the bolt with the suspension loaded. There will be minimal movement from there and the provided lubricant should prevent any binding.
I put them in and am happy. Have not been to the track yet with this setup but don’t expect problems.
Old Jun 5, 2021 | 05:17 AM
  #41
RudeJoe's Avatar
RudeJoe
I am considering this upgrade and found a '08 parts car. The guy says the trailing arms are steel not aluminum and sent a picture that confirms it. Assuming he's looking at the right car which could this be? It's not a Clubman because it has a hatch. I just need to know what not to look for in a parts car if all are not aluminum. Thanks
Old Jun 5, 2021 | 05:29 AM
  #42
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Do you have the pictures of the trailing arms from that car? If its an R56, they should be aluminum.
Old Jun 5, 2021 | 06:06 AM
  #43
Edoardo Marzi's Avatar
Edoardo Marzi
This is an R56 so it has aluminum rear trailing arms, you also need the rear struts bushings to fit your rear struts into the new trailing arm.
That picture doesn't confirm anything, that's only a rusted brake disc hahaha
Old Jun 6, 2021 | 02:26 PM
  #44
Kitchenboy's Avatar
Kitchenboy
These are the strut bushing adapters I bought on ebay. https://www.ebay.com/itm/Mini-Cooper....m46890.l49286
Old Jun 6, 2021 | 05:37 PM
  #45
RudeJoe's Avatar
RudeJoe
Yes, I know it is just a picture of a back end of a messed up car. Unfortunately I deleted the image of the trailing arm (still on the car) after he insisted it was steel. I'm a ways away from the car so I needed to confirm everything is good before making the drive. He had 1st gen Mini that we was parting also so I was thinking maybe he took a picture of the wrong car. But he stopped responding to communication so I need to keep looking.
Old Jun 6, 2021 | 06:45 PM
  #46
Kitchenboy's Avatar
Kitchenboy
Check this guy out. That's where I bought my setup. He included everything needed including hardware. All I had to buy was the strut adapters. https://m.facebook.com/pages/categor...5741925490737/
Old Sep 14, 2021 | 05:47 AM
  #47
hansvongeldern's Avatar
hansvongeldern
I just bought Megan Racing bushing, so can I put them in my '06 R53 brackets or should I use R56 brackets anyway?. Anybody knows if there is a real difference between both brackets besides the bushing?. In pictures they both looks very similar
Edge
Suspension
45
Sep 14, 2021 05:48 AM
Timbo14
Suspension
12
Nov 19, 2019 07:09 PM
mathewkhng
Suspension
Jan 13, 2019 09:34 PM
seewavedr
Jul 8, 2012 11:24 AM
Dreammaker
Suspension
Jan 22, 2010 12:41 PM
