Suspension Fat Cat bump stops and NM Springs
Old Apr 12, 2018 | 05:11 PM
tag1260's Avatar
tag1260
Who's running Fat Cat Motorsports bump stops with NM Springs? Did you trim the bump stops down and if you did how much? Thanks
Old Apr 16, 2018 | 11:38 AM
BigBoost's Avatar
BigBoost
I did a little google search ‘ they look pretty eBay!
Would just go with power flex bumb stops & call it good
Old Apr 18, 2018 | 09:54 AM
tag1260's Avatar
tag1260
Well, if you contact Fat Cat Motorsports for info on ther products, they charge a $75.00 consulting fee so I recommend going another route as they charge for product support.
X5 Racing, who sells them said to contact Fat Cat as they didn't have the info on cutting.
Old Apr 19, 2018 | 08:22 AM
mbwicz's Avatar
mbwicz
I'm not running NM springs, but I did cut mine. I'll measure them when I get home and post the results. I ended up trimming them in steps, it seems like 1-1/4" clearance/travel on the rear was about right. Less than that and it got really stiff really quick.
Years ago I tried urethane bump stops with TSW springs and stock shocks and I destroyed the bump stops (they got sheared from bottoming too much). The fat cat stops seem durable in the year that I've run them.
Mike
Old Apr 19, 2018 | 08:28 AM
tag1260's Avatar
tag1260
Thanks. What kind of springs are you running?
Old Apr 19, 2018 | 11:46 AM
mbwicz's Avatar
mbwicz
I'm running sport springs in front and 275 lb coil over springs in the back. I have bilsteins with the threaded lower mount and made upper mounts for them. The car seems happy with the higher rear spring rate.
Mike
tag1260
Apr 11, 2018 06:01 PM
Mini2na
Suspension
23
Nov 13, 2014 08:02 AM
MotoGreg
Suspension
12
Aug 22, 2007 03:07 PM
RED5
Suspension
Jun 13, 2005 06:40 PM
