Suspension Rear Camber Arms with Provisions for Headlight Leveler
Old Jul 10, 2017 | 07:08 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I am in the market for a set of rear camber arms, but I have the headlight leveler back there.
Do any of the aftermarket arms have provisions for the leveling sensor? None of them "appear" to have provisions, at least based on the marketing pictures.
Old Jul 10, 2017 | 09:24 AM
RB-MINI's Avatar
RB-MINI
Are you replacing all four arms? If not, you probably don't need to change anything as the leveler should be on the upper drivers side arm and only the lowers need replacing to adjust the camber. Upper adjustable arms are needed for more serious handling setups, or for toe problems that can't be corrected with the stock adjusments.
If you're replacing the upper arms, Hotchkis has a small optional bracket that wire ties to the arm. On eBay, Donald the Bonald sells a bracket for his arms. You can also make your own using a clamp, L-bracket, and a ball end from a hobby shop.
Old Jul 10, 2017 | 09:31 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Maybe that's why I'm not seeing it. I thought the leveling sensor was on the lower arm!
My plan was to only replace the two lower arms to help with camber adjustment after installation of coil overs.
Old Nov 22, 2021 | 06:19 AM
2out2sea's Avatar
2out2sea
Old thread, but my Megan racing arms came with a nifty bracket. Just fyi.
brad
youloze
Suspension
Nov 18, 2013 07:05 AM
Johan
Aug 12, 2013 04:15 PM
JIMJMN
Suspension
Jan 23, 2009 07:09 AM
freeskier
Suspension
62
May 16, 2008 07:21 PM
S1monLM
Suspension
Jan 1, 2005 08:02 AM
