Suspension AC Schntizer Spring Kit
Old May 25, 2016 | 05:51 PM
GregoryK's Avatar
GregoryK
Anyone install these yet. Not a huge drop...but their stuff speaks for itself.
Old May 25, 2016 | 11:40 PM
blue al's Avatar
blue al
Have you a link ?
As it's not speaking loud enough...
So currently I haven't a clue what the drop is....
Old May 26, 2016 | 04:23 AM
GregoryK's Avatar
GregoryK
20mm
http://preisliste.ac-schnitzer.de/ac...hl=3-Türer-F56
Look around the site they have other high quality stuff.
Old May 27, 2016 | 10:43 PM
blue al's Avatar
blue al
Description from the uk site....
AC Schnitzer suspension springs are engineered to improve handling and looks while retaining ride quality. The reduction in ride height of approx 30mm (20-25mm for JCW) and progressively wound springs reduce body roll, improve turn-in and increase grip in all conditions without making the ride harsh or affecting the steering negatively.
Please choose the correct model option from above when ordering. JCW version available to pre-order now with delivery early March 2016.
I have seen a similar variation in drop with s and Jcw on the eibach site
So I'm not sure if the Jcw springs are manufactured longer or they assume factory ones are shorter so you see a smaller drop
Old Jun 1, 2016 | 11:40 AM
We have the AC Schnitzer @ ECS Tuning now.
F56 S: https://www.ecstuning.com/Search/SiteSearch/3130256310/ 3130256310
F56 JCW 3130256410
https://www.ecstuning.com/Search/SiteSearch/3130256410/
When developing spring on a car that already lowered, that was the range they selected for ride and comfort. I have seen it on other brand springs. So its not like the S and the JCW started at the same height. I believe the On the gen 1 MINIs the JCW sport suspension was 10mm lower then the Cooper S stock. Even through the JCW shared the same sport suspension on the Cooper S , in my spring calculator it shows different spring part number ranges. I have not seen the factory JCW spring weights so I bet they ride lower.
Old Jun 1, 2016 | 01:06 PM
blue al's Avatar
blue al
Thanks for heads up
I cannot find any Spring refs for std cars or Jcw, on the f56
Everything I had found suggested parts were the same
but I knew my r53 with ss+ ran lower from the factory so it good to have this confirmed (even nearly)
Old Jun 1, 2016 | 01:08 PM
Welcome, yea there is no info on MINI side as the F56 is so new. MINI does not also tell me there springs rates through the internal system.
Old Jun 1, 2016 | 08:18 PM
vetsvette's Avatar
vetsvette
Moderator
I have the SS option on my car and didn't notice any difference in ride height compared to a car with standard suspension. After the NM spring install there is a marked difference.
earth_to_aj
Suspension
Jan 13, 2017 02:03 PM
otfox
May 26, 2016 12:33 PM
99mpower
May 25, 2016 10:16 AM
Caljae1
R55 :: Clubman Talk (2008+)
May 24, 2016 05:14 PM
simpsoap
May 9, 2016 12:53 PM
