Suspension front arm bushings, from R56?
Old Mar 13, 2016 | 03:47 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I cannot run poly bushings due to autocross rules, anyone swapped in R56 bushings? They look like they are quite a bit more solid, and rubber that's the key as I have to have same material as stock
I've not had any luck finding solid rubber bushings, only poly and I cannot use them it bumps me into a much faster class
Old Mar 13, 2016 | 11:03 PM
jgk6502's Avatar
jgk6502
A local shop, (edge motor works), recommended I change my bushings. I asked if they use poly. They said they use a BMW rubber compound that was better than MINI OEM. Not sure if it was true, but maybe something you could look into.
Old Mar 22, 2016 | 06:30 AM
X757XVeritas's Avatar
X757XVeritas
Someone correct me if I'm wrong, but aren't the r56 fluid filled? They may look solid but are not I believe.
Autocross really sticks it to you with rules sometimes when you are trying to fix a known common failure point lol.
Old Mar 22, 2016 | 07:51 AM
MrBlah's Avatar
MrBlah
probably more solid than r53 if they work!
Still trying to find some solid rubber ones, same issue with engine/trans mounts
Old Mar 22, 2016 | 09:59 AM
X757XVeritas
How does your autocross people feel about window weld.........lol You can full the air pockets and cracks in with window weld. Technically you would still have the factory mounts and bushings still. But the window weld will make them "solid". And if you take your time and smooth it out nice it will look like something factory
Last edited by X757XVeritas; Mar 22, 2016 at 10:02 AM. Reason: Autocorrect thinks it's better than me.
Old Mar 22, 2016 | 08:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've installed hundreds of sets of control arm bushings and can say the R56 bushings do seem to be more durable.
If you are running nationally or a serious group beating on the rules then you need to stick with stock. And even switching to the R56 ones would be cheating as they aren't the originals for an R53. But if you are just doing it for fun go with the powerflex. We never install the stock ones in our shop as we don't want customers having to replace them again the powerflex becomes the best and only way to go.
http://www.waymotorworks.com/powerfl...shing-kit.html
If you want new rubber ones I've got a bunch of cheap ones that are brand new we pressed out of new brackets to make cores for our prepressed bushings
http://www.waymotorworks.com/rubber-...0-r53-r52.html
Old Mar 23, 2016 | 03:17 AM
MrBlah's Avatar
MrBlah
Powerflex definitely no go, I can use any rubber with same offset I just put a new set in, I think next set will be r56 if offset is the same
ra2fanatic
May 12, 2016 06:02 PM
wellzy
Apr 18, 2016 10:28 PM
freestylin599
Mar 29, 2016 10:23 PM
rikaro
Tires, Wheels, & Brakes
Mar 23, 2016 08:19 AM
thebombardier
14
Mar 10, 2016 02:57 PM
