Suspension Suspension: Stock vs. FSD vs. B4 ??
Old Mar 13, 2019 | 09:44 AM
  #151
These old KONI ads for Mini are really cool and some old ferrari back in the day.
View this post on Instagram
Old Mar 13, 2019 | 09:47 AM
  #152
Originally Posted by Soul Coughing
When with the FSR's be back on sale? What time of the year usually? If someone was to make an educated guess...
Click the link we are doing a short time sale
https://www.ecstuning.com/b-koni-parts/v-mini/
Old Mar 13, 2019 | 12:39 PM
  #153
Andy_S's Avatar
Andy_S
Just FYI... the way you've priced these, the kit 8745-1012 costs about $6 more than buying its four components.
Old Mar 13, 2019 | 12:57 PM
  #154
Fixed, sorry about that. Its did not link on the back end.
Old Nov 10, 2019 | 08:29 PM
  #155
cesare's Avatar
cesare
I've been searching awhile now for the Bilstein Sports (B8) for the R53 but have only been able to find the HD's (B6) so far.
If anyone has an idea where to source the B8's from these days it would be much appreciated!
Old Nov 11, 2019 | 05:34 AM
  #156
Eddie07S's Avatar
Eddie07S
The Bilstein web site does not list a B8 for the R53...
https://www.bilstein.com/us/en/produ...13473343376520
Seems like you might be out of luck here.
Shocks for the R56 will fit the front of the R53. The rears have a tapered seat on one side of the lower mount that would have to modified. A while back I saw threads with people doing this. I know that Way Motors used to sell a conical washer for installing R53 shocks in an R56. So vice versa should work. Does that help?
Why not go with the Koni Yellows if you can’t do the B8s?
Old Jun 26, 2020 | 12:01 AM
  #157
mstorck33's Avatar
mstorck33
Dumb question: Are the Koni red FSD's an updated version of the gold (not yellow) colored ones? I've seen a few images online of Koni FSD shocks that are gold colored, and more images that are red, and I haven't been able to find any info about the color difference. I'm assuming the gold ones were a previous version? Sounds dumb but i can't find anything explaining the difference...
Old Jun 26, 2020 | 04:15 AM
  #158
Eddie07S's Avatar
Eddie07S
This might help:
https://www.eeuroparts.com/blog/koni...pecial-active/
Old Jun 26, 2020 | 08:10 AM
  #159
haygood's Avatar
haygood
The new version of the FSD's looks interesting. The FSDs were not supposed to be used with lowering springs, so being able to do that with the Special ACTIVE version is cool. I'm still quite happy with our FSDs, which we've had for quite a few years now. By the looks of it, the new ones might be a little better suited to track use. I never noticed a problem with the FSDs, but others mentioned they don't do as well on the track as the normal Konis do. According to the literature, the new ones should fill that roll better. Very cool.
Old Jun 28, 2020 | 12:26 PM
  #160
mstorck33's Avatar
mstorck33
Thanks for that link, I actually wound up calling Koni directly before I saw your reply, and the guy confirmed that the red ones are indeed the replacement for the FSD. I think I'm going to pull the trigger and get some for my '05 R52 when I have the finances available.
Old Jul 6, 2020 | 02:59 PM
  #161
eimkeith's Avatar
eimkeith
wait; you CAN use lowering springs with the SAS?
Old Jul 6, 2020 | 04:58 PM
  #162
cristo's Avatar
cristo
Alliance Member
I wouldn’t bet on it.
Most sites that sell them for MINIs
don’t mention lowering springs, a
few say don’t lowering springs them
with the MINI applications, and a
couple say it’s ok but just give Koni’s
generic ad copy for the special active
series in general, not for the specific
application.
Old Aug 8, 2020 | 08:20 AM
  #163
GearheadS's Avatar
GearheadS
Just want to add my thumbs up to the Koni red FSD struts. Just installed all 4 on my 05 R52 MCS, 170k miles. Same springs. Mostly the same rubber parts, it was all good except the front strut boots! The harshness of this go-cart is noticeable reduced over little, sharp edged jiggly bumps, and the handling feels good.
Shout out to ECS for great price and delivery.
Jeremy
Old Oct 3, 2020 | 11:46 AM
  #164
mountainhorse's Avatar
mountainhorse
Originally Posted by mountainhorse
Is there a kit of "soft items" at a 'fair price' that, IMO, should be replaced on any 60k-mile+ shock replacement/upgrade (non coilover)?? Items in RED
Also, is there any better place to get the METAL, 2-bolt upper rear-shock flange, in the aftermarket... $82 for the stock mini part is CRAZY for that part.
REAR
Bump for Tommy,
Here are the parts to the shocks and struts... Upper mounts, jounce bumpers, spring pads, bushings, bellows etc.
Old Oct 3, 2020 | 03:54 PM
  #165
mstorck33's Avatar
mstorck33
As soon as I get some money, I'm probably going to get the Koni FSD's for my R52, and also thinking about updating/upgrading all the rubber bits.
Old Oct 3, 2020 | 04:19 PM
  #166
mountainhorse
Really nice package.... on a street driven car... with an uprated rear swaybar... gives amazing handling... and better performance than most coilover setups or 'adjustable' strut/shock combos because it's not lowered and has more travel to deal with the 'real world" .... keeps the tires on the pavement ... which is good
Old Oct 6, 2020 | 10:27 PM
  #167
Mini_Crazy's Avatar
Mini_Crazy
Originally Posted by GearheadS
Just want to add my thumbs up to the Koni red FSD struts. . . it was all good except the front strut boots!
Jeremy
Koni and many other "performance" struts don't come with the strut boots or "gaiters", and if you trim the original bumpstops you have nothing to attach those OEM gaiters to either. . . but there is a simple solution:
Buy a pair of BMW #33526764418 strut washers for a few bucks, enlarge center hole if necessary to match your new struts, and attach your Mini gaiters to them. This will work with trimmed OEM bumpstops, or aftermarket (like the trimmed FatCat bumpstops I'm using with Koni yellows) or the ones that come with the FSDs.
The gaiters help protect the strut shafts from winter slush & gravel, and they weigh next to nothing.
wikdr53
Mar 9, 2019 04:29 PM
NYMADMINI
Apr 15, 2015 11:38 AM
IQRaceworks
38
Feb 5, 2012 07:22 AM
suwipin
Suspension
17
Nov 12, 2008 09:33 PM
Nor_Cal_Mini
Suspension
May 4, 2007 08:30 AM
