Suspension Bilstein PSS9 Coilovers
Old Aug 5, 2005 | 06:44 PM
  #126
chrisfb1's Avatar
chrisfb1
shox.com is out
other shops are out too.
apparently, everyone of them go thru Distributors, they do not keep them since it is a high price inventory item.
they all use drop shipping methods. yo order and they orders.
i have tried all of them, electordyn is the last one i need to ask to find out if they have it or not.
any idea where else?
maybe i need to call the mexico store and see if they have some, that is the closest one to USA!
Old Aug 5, 2005 | 07:16 PM
  #127
onasled's Avatar
onasled
Nothing at Turner????
Old Aug 5, 2005 | 07:18 PM
  #128
chrisfb1's Avatar
chrisfb1
turner is out too.
like i have said, NO ONE has it!
this is the first time that i have ever run into something that no one has available. not even the distributor!
maybe i need to buy a Alta largeIC to cool down my fever oh!
help guys, locate one for me!
call me 24/7 if anyone has one!
917 498 5538
Chris
Old Aug 5, 2005 | 07:39 PM
  #129
onasled's Avatar
onasled
I gotta tell ya, at this point I personally would consider the Tien system. Might be a tad stiff for the road though, but I think my PSS9s need to be stiffer for the track so that's why I am thinkung this way.
Old Aug 5, 2005 | 08:39 PM
  #130
Dr Obnxs's Avatar
Dr Obnxs
Can't you
just get different springs? Or do they run out of damping?
Matt
Old Aug 5, 2005 | 08:40 PM
  #131
chrisfb1's Avatar
chrisfb1
at this point, nothing at all
Old Aug 5, 2005 | 08:55 PM
  #132
TonyB's Avatar
TonyB
I have heard of guys going linear, and stiffer up front on the PSS9s; and to be honest, knowing that was a viable option also helped in making the decision a bit easier to go the PSS9 route...
Old Aug 5, 2005 | 09:05 PM
  #133
k-huevo's Avatar
k-huevo
May be you should try some Ledas . I know where you can get a set .
Old Aug 5, 2005 | 09:14 PM
  #134
Dr Obnxs's Avatar
Dr Obnxs
Lmfao!
Thanks...
Old Aug 7, 2005 | 12:42 PM
  #135
TonyB's Avatar
TonyB
Anyone know where I can find the PSS9 instructions online? I thought that I might be able to locate a PDF somewhere, but I was unable to. Truth be told, I only tried for about 2 minutes...
Thanks much for your help.
Old Aug 7, 2005 | 01:44 PM
  #136
onasled's Avatar
onasled
Tony
What is it you need as there is not much there. I can scan te three pages that have info. One is which way to turn the ***** and the others are hight suggestions.
Let me know and I'll do that this afternoon.
Old Aug 7, 2005 | 02:25 PM
  #137
TonyB's Avatar
TonyB
onasled, if it's not much trouble, I would really appreciate it! Just saw your post in the camber plate thread. Hope I'm not putting you out too much...
Old Aug 7, 2005 | 02:38 PM
  #138
chrisfb1's Avatar
chrisfb1
you guys are so lucky to have PSS9
Old Aug 7, 2005 | 03:33 PM
  #139
onasled's Avatar
onasled
Tony. PM sent ...
Chris, just what are they saying about lead time on these?
Old Aug 7, 2005 | 04:10 PM
  #140
chrisfb1's Avatar
chrisfb1
someone say October someone say September.
someone say end of august. no one knows
Old Aug 8, 2005 | 05:07 AM
  #141
meb's Avatar
meb
I was told anytime between August and October. Argh!
Old Aug 8, 2005 | 06:58 AM
  #142
red rage's Avatar
red rage
s
Stiffer? Man, just weld the frame to the wheels
You have to have some cushion and comfort in a car
I noticed a big change for the better with the PSS9, on and off the track
Phil
Old Aug 8, 2005 | 09:37 AM
  #143
iDiaz's Avatar
iDiaz
Coordinator :: Motoring Underground Club Forum
The only time you need to go to a stiffer spring rate is when your suspension stroke is shortened (because of lowering for a lower CG) to the point that the spring rate is no longer sufficient to prevent the suspension from bottoming out over the hardest bump you plan on driving on, be it on an autocross course, road course, or canyon road. Contrary to popular belief, only reponsiveness is improved with a stiffer spring, but ultimate cornering speed is not. Improvements in cornering speed come from lowering the center of gravity, not simply stiffening the springs.
More info here: http://www.teammightyminiz.com/forum...=2266&start=90
Old Aug 8, 2005 | 11:45 AM
  #144
flyboy2160's Avatar
flyboy2160
new bilstein design?
(i just started a separate thread for this)
did any of you notice this listing for a 'BSS' mini coilover?
http://www.racers.jp/mini/index.html
it looks much different from the pss9 and it doesn't show on the bilstein website.
Old Aug 8, 2005 | 12:12 PM
  #145
J0kER's Avatar
J0kER
would U' happen to know if the finish of the tube will resist corrosion during winter months??
Old Aug 8, 2005 | 12:50 PM
  #146
iDiaz's Avatar
iDiaz
To be honest, I don't really know. It looks to be nickel plating, but I'm not sure. I'm from Southern California, so it was never even a consideration.
Old Aug 8, 2005 | 12:53 PM
  #147
J0kER's Avatar
J0kER
kool...
Old Aug 8, 2005 | 01:01 PM
  #148
meb's Avatar
meb
But don't forget that lowering the center of gravity with a McPhearson strut lowers the roll center dis-proportionately which will adversley affect cornering power. Swaybars also improve responsiveness; keep the stock sway bar front to rear ratio the same, but increase the size of each say by 25-50% and the car will be more responsive.
Old Aug 8, 2005 | 01:39 PM
  #149
iDiaz's Avatar
iDiaz
How does this adversely affect cornering power? A MacPherson strut design, given too high of a roll center and what is basically fixed camber through the stroke caused by the strut determining suspension geometry, will eventually "run out" of camber given excessive body roll. A lower roll center reduces this effect, allowing you to run slightly less aggressive camber settings than you would if the roll center were higher.
Responsiveness and cornering speed are two different issues. Remember, the far end of the "responsiveness spectrum" is instability.
Old Aug 8, 2005 | 04:19 PM
  #150
iDiaz's Avatar
iDiaz
Ahhh... I follow what you're saying. I found this article that illustrates it perfectly:
http://e30m3performance.com/myths/We..._transfer2.htm
Fortunately, the increase in spring rate serves to offset the increased roll rate, so you get the benefits of the lower center of gravity without magnifying the poor geometry of the MacPherson strut.
