Suspension How to: Lowering Springs
Old Nov 11, 2013 | 01:56 PM
myR56S's Avatar
myR56S
Does anyone know where I find how to instructions for installing springs? The search is not bringing up much.
Old Nov 11, 2013 | 02:41 PM
minibx's Avatar
minibx
Try this I hope it helps https://www.northamericanmotoring.co...ll-how-to.html
Old Nov 11, 2013 | 02:57 PM
myR56S's Avatar
myR56S
Originally Posted by minibx
Hi Minibx,
What I was really needing was if the nuts holding the rear strut on are inside the car (pull apart the rear interior) or are they accessible from the outside of the car.
Old Nov 11, 2013 | 03:11 PM
minibx's Avatar
minibx
Hi they are accessible from underneath the car, pretty easy just make sure that you mind the brake lines and such
Old Nov 11, 2013 | 03:54 PM
myR56S's Avatar
myR56S
Perfect, thank you.
One last question, do you have to have that special 21mm socket or would any deep 21mm work?
Old Nov 11, 2013 | 04:12 PM
minibx's Avatar
minibx
Originally Posted by myR56S
Perfect, thank you.
It would be nice to have it but if you don't and I didn't have it, you can use a spark plug socket with and Allen key I can't remember the size ?/16 sorry bad memory but it works on the 21 if you are keeping the same struts, if you are changing the struts they may be 22 mm instead and that will complicate things a bit but not much lol, just make sure that you have a spring compressor, rent from your chain auto parts store or buy one ( I would rent). I see that you have an R56 in my opinion they are easier to than the r53's to swap springs. Good luck
Old Nov 11, 2013 | 04:25 PM
myR56S's Avatar
myR56S
Thank you minibx. I appreciated your time and your assistance. I'll snap some shots when she's all done (weather is changing fast)
Old Nov 11, 2013 | 05:47 PM
minibx's Avatar
minibx
Cool we like pics lol
Old Feb 10, 2014 | 04:02 PM
myR56S's Avatar
myR56S
I almost forgot about pics! Is it too late? Haha.
How to: Lowering Springs-forumrunner_20140210_170108.jpg
How to: Lowering Springs-forumrunner_20140210_170127.jpg
How to: Lowering Springs-forumrunner_20140210_170200.jpg
Old Feb 10, 2014 | 05:03 PM
minibx's Avatar
minibx
Sweet, any issues?
Old Feb 10, 2014 | 05:11 PM
myR56S's Avatar
myR56S
Sweet, any issues?
Wouldn't be a Mini mod without an issue.
My car suffers from a vibration right around 30 MPH. If I am too aggressive with the skinny pedal I get a bad vibration. It's easy to live with for now. Heard replacing the axle will resolve the issue. The car only has 60k on it so I'm not going to replace it just yet.
The Mach V motorsports spring is a 1.25" drop up front and 1.0" in the rear. Easiest mod I've ever done. One hour, forty minutes.
Wouldn't mind a more aggressive drop.
Old Feb 10, 2014 | 05:18 PM
minibx's Avatar
minibx
That's a pretty cool drop I hope that you can fix the vibration I couldn't live with lol. Looks great enjoy
Old Feb 10, 2014 | 08:47 PM
Wrecks's Avatar
Wrecks
Stock shocks?
Old Feb 10, 2014 | 08:55 PM
myR56S's Avatar
myR56S
Originally Posted by Wrecks
Stock shocks?
Yes, stock SS. Works very well together. Couldn't be happier.
Old Feb 10, 2014 | 08:59 PM
Wrecks's Avatar
Wrecks
Yeh just wondering, on my other car one of my shocks started to leak causing a vibration that would only happen at 55+ mph. Car was lowered with only 15k miles.
The other time it vibrated was cause all the weights were gone.
Old Feb 10, 2014 | 09:01 PM
myR56S's Avatar
myR56S
Wow, that's hardly any miles! Frustrating
Old Mar 17, 2014 | 06:39 AM
myR56S's Avatar
myR56S
Good morning minibx,
Just wanted to give you (and NAM) an update on my axle vibration. I found a reman CV from O'Reilly Auto parts. It was only $100.
After getting the wrong axle the first time (long story) I finally got the correct axle and replaced that yesterday. 40 mins later my car was vibration free. BTW this was a super easy job!!
While this was a gamble for me I did have some insight from my brother (a mechanic), he stated that most unequal length axle setups (like the Mini) tend to wear out the shorter side first (driver side in our case) mainly because the long side will 'wrap up' or twist when heavy accelerating is applied. This twisting of the long axle can prolong its life. Well that theroy was proven yesterday. While the axle is not 100% vibration free I can barely feel it now and I can live with that.
Now to figure out my new coolant leak that I just noticed
Old Mar 17, 2014 | 09:38 AM
minibx's Avatar
minibx
Good morning minibx, Just wanted to give you (and NAM) an update on my axle vibration. I found a reman CV from O'Reilly Auto parts. It was only $100. After getting the wrong axle the first time (long story) I finally got the correct axle and replaced that yesterday. 40 mins later my car was vibration free. BTW this was a super easy job!! While this was a gamble for me I did have some insight from my brother (a mechanic), he stated that most unequal length axle setups (like the Mini) tend to wear out the shorter side first (driver side in our case) mainly because the long side will 'wrap up' or twist when heavy accelerating is applied. This twisting of the long axle can prolong its life. Well that theroy was proven yesterday. While the axle is not 100% vibration free I can barely feel it now and I can live with that. Now to figure out my new coolant leak that I just noticed
Thanks for the upgrade, I'm glad that all worked out for you. If most of the vibration went away but you still feel some. You can check you wheels and tires try using a shop that has road force balance it will help a lot , not all shop use road force
Old Mar 18, 2014 | 05:24 AM
aklucsarits's Avatar
aklucsarits
The problem is that shocks, especially OEM shocks, are designed to dampen oscillations within a certain specified motion range. When you put 1" lowering springs on your car, the motion of the shock/strut isnow starting 1" already into its designed and intended stroke range of motion. The first inch of dampening is now never used, and the remaining range of damping motion has to do ALL the dampening. This is why lowering springs typically wear out OEM shocks/struts rapidly on almost any car.
Old Mar 18, 2014 | 07:12 AM
minibx's Avatar
minibx
That's why I can't lower my car, I have Koni FSD on my Mini. There is one memeber that had good results installing JCW spring with 0 problems so far so who knows I guess it will shorten the life of the shocks eventually.
Old Mar 18, 2014 | 09:34 AM
mbwicz's Avatar
mbwicz
My R56S,
Check the coolant overflow bottle on Winnie. Mine had a small crack on the bottom of it, so it would only leak when the car was hot. If the top of the trans is wet, it is the thermostat, the water pump is on the passenger side of the engine.
Have fun,
Mike
patsum
26
May 29, 2021 06:29 PM
smdmini
Oct 7, 2019 06:05 AM
Supertractor3
Apr 7, 2017 11:16 AM
ej
Nov 17, 2015 09:21 PM
Sep 2, 2015 11:15 AM
