Suspension Strut brace install question
Old Sep 15, 2013 | 08:30 PM
tbearmini's Avatar
tbearmini
I bought a Bavauto upper strut brace from classifieds here. The two upper mount studs on each side aren't long enough to safely attach the brace. Any thoughts on how to remove the studs from the shock mount and replace with a bolt?
Old Oct 13, 2013 | 06:31 PM
Quitman Rhinehardt's Avatar
Quitman Rhinehardt
Did you take the two nuts off the shock tower first?
Old Oct 14, 2013 | 06:54 AM
tbearmini's Avatar
tbearmini
Yeah, took the nuts off but there doesn't appear to be enough remaining threads to safely put the brace and the nut back on.
Old Oct 15, 2013 | 04:48 AM
Quitman Rhinehardt
What year and model mini? can you post a pic?
Old Oct 15, 2013 | 05:31 AM
tbearmini's Avatar
tbearmini
Yeah, let me do that tonight when I get home. 2006 base coupe.
Old Oct 16, 2013 | 06:30 AM
tbearmini's Avatar
tbearmini
Well, not good at attaching pictures so added to my album.
https://www.northamericanmotoring.co...ads-78930.html
Old Oct 16, 2013 | 07:53 AM
Quitman Rhinehardt
It looks like your strut brace mount is thicker than most i've seen (mine included). as long as you can torque it down enough i wouldn't worry about it. If you can't tighten it I would just grind down the top of the strut mount holes on the brace. The bolts on the strut mount are pressed into the mount which could be removed but finding longer ones may be a problem. not to mention you would have to remove the strut to do it.
Old Oct 16, 2013 | 05:37 PM
tbearmini's Avatar
tbearmini
Really don't want to grind on the car. Wonder what it would take to try on the brace mount itself?
Old Oct 16, 2013 | 07:36 PM
Quitman Rhinehardt
Yeah thats what I meant. grind the brace down where the nuts would sit.
Old Nov 19, 2013 | 07:16 PM
tbearmini's Avatar
tbearmini
Well, did all the grinding and now it hits the hood. Sent email to bavauto to see what I need to do to make it fit. It looks like the battery box is in the way.
Old Nov 23, 2013 | 12:20 PM
tbearmini's Avatar
tbearmini
Anyone modded their battery cover to fit a strut bar? Was going to dremel it with a groove for the bar but worried about water getting into the battery/ecu.
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Dec 23, 2015 10:36 AM
squawSkiBum
Oct 2, 2015 09:21 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
