Suspension Replacing Control Arm Bushing
Old Dec 26, 2011 | 02:37 PM
IDOXLR8's Avatar
IDOXLR8
I'm looking to replace the front control arm bushings on my 2003 MINI. I have the OEM style with the brackets from the dealer. At this point I would like to replace only the ones towards the rear of the car and looking to do this with out removing the complete arm. Is this possable? I see the sub frame must be lowered for bolt clearance, what a mess any help out there? Thanks, AL.
Old Dec 26, 2011 | 05:53 PM
boxer's Avatar
boxer
In the search field, type "replace control arm bushings". I bet you locate much help. Good luck.
Old Dec 26, 2011 | 08:12 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes search control arm bushing replacement. But basicly you disconnect the steering rack from the column and remove all the subframe bolts then pry it down and remove them.
FYI this thread you have posted in the 2nd gen forum, your 03 is a 1st gen car a mod. may move this.
Old Dec 26, 2011 | 08:17 PM
IDOXLR8's Avatar
IDOXLR8
Control Arm Bushing Removal
I consicered removing the complete sub-frame and read the front bumper had to be removed and something about the core support . I'm looking into dropping the sub-frame and see if the bushing will come out, AL.
Old Dec 26, 2011 | 08:20 PM
IDOXLR8's Avatar
IDOXLR8
I did a search and didn't see anything on just lowering the sub-frame for removal, just complete removal, AL.
Old Dec 26, 2011 | 08:25 PM
IDOXLR8's Avatar
IDOXLR8
Here is the link http://www.minicooperspeed.com/mini-...-r50-r53remov/
Old Dec 28, 2011 | 02:08 PM
IDOXLR8's Avatar
IDOXLR8
Separating The Lower Ball Joint
Separating The Lower Ball Joint at the steering knuckel, removed the to 13mm bolts and wouldn't separate. I'm looking into the press tool that separates the ball joint from the other end, any ideas? AL.
Old Dec 28, 2011 | 02:19 PM
IDOXLR8's Avatar
IDOXLR8
Control Arm Bushing Replacement
I did get the old worn out bushings off and the new ones on now need to finish the rest of the job. I admit I went about some of this backwards like not removing the sub-frame and installing the bushings on the control arms then installing the control arms on the car . I found my coolant leak wile doing the repairs and looks like a radaitor leak , It looks like another PITA repair and will need input from you guys when I start this new adventure , AL.
Old Jan 4, 2012 | 10:33 AM
IDOXLR8's Avatar
IDOXLR8
Reporting back, the front end work is done and went well thanks to you all and your support. I wanted a softer ride then the Power Flex offered and figured they would be fine on interstate roads but where I live out in the sticks OEM was the way to go, thanks again! Now to make a post on a coolant leak at the front left corner of the car, AL.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
