Suspension Increasing ride height
Old Jan 1, 2013 | 08:19 AM
  #76
miniMAUL's Avatar
miniMAUL
Sorry for the delayed reply. Getting ready to move from Florida to DC at beginning of the year.
Originally Posted by Burchie
Update?? How's things holding together?
So far all is working out fine. Just at 3,300 miles on it since the lift... 9,900 miles total. No issues. The Countryman still zips thru the turns, no loss of control and no suspension issues. I still seem to get a higher percentage of comments when parking it as opposed to before it was lifted. People will stop and ask about what tyoe of MINI it is, about the All Wheel Drive, etc.
I can't say enough about swapping out the tires, getting rid of the run flats has made the ride so much better. On rough roads the handling is better because at speed the jarring of the run flats made it unbearable.
Originally Posted by bmwr606
did you need an alignment after the lift kit was installed?
thanks
scott
Yes and the guys at OxSpeed took my Countryman and the new wheels and tires I had shipped from TireRack to a local tire shop for mounting and alignment after installing the lift.
Will be getting tires rotated this month, before I make a couple long drives bewteen Florida ad DC in the coming months. Will get tire wear and alignment issues checked out and see how the Pirelli Scorpions are holding up.
Old Mar 8, 2013 | 04:21 PM
  #77
WorldWideTigger's Avatar
WorldWideTigger
Hey MiniMaul;
I just purchased a 2'' lift kit with BMW sway bar drop links from Helix13mini. I was just curious if you ended up having tire wear or alignment issues as stated in your last post. I look forward to hearing from you.
Thanks, Tiger
Old Sep 30, 2013 | 09:08 AM
  #78
inclinelongboards's Avatar
inclinelongboards
1in Lift in Rear
I have some 19x8.5 et40 rims that rub just slightly in the back and was looking to lift the rear about an inch to get the clearance I need. Has anybody found a kit that isn't 2 inches?
I think a 1 inch lift in the back will give it a nice aggressive look and the clearance I need with my offset wheels, but I can't seem to find a good solution.
Old Nov 25, 2013 | 10:12 PM
  #79
bigfiero's Avatar
bigfiero
can i play with my big brothers?
2" lift kit from Coopercrap.com
bassett -25 offset wheels
215/60/15 snowtrakker tires
aries pushbar
stingray lowprofile roof rack
4.5" 4X27W LED Flood Lights
4.5" 4X27W LED Spot Lights
1" front and rear rubber spring spacers
Old Dec 10, 2013 | 07:00 PM
  #80
tominizer's Avatar
tominizer
Cool thread............
Old Jan 8, 2014 | 03:17 PM
  #81
Ooops's Avatar
Ooops
Updates? Long term reviews?
Are there any other lift kits being offered or other methods or higher than 2"?
Old Jan 14, 2014 | 07:05 PM
  #82
SmallCarsRock's Avatar
SmallCarsRock
I'd also be interested in updates from anyone who's been running with theirs lifted for a while.
Old Jan 14, 2014 | 08:55 PM
  #83
HorseWithNoName's Avatar
HorseWithNoName
Originally Posted by Patarix
Hello,
We live in a place where we could use a couple of cm (or about 1 inch) of increased ground clearance. Is there a way to increase the ride height? What kind of modification would I need to do?
Thanks,
Alessandro
What tire and wheel package do you have now?
Old Jan 14, 2014 | 09:05 PM
  #84
HorseWithNoName
Hi guys,
I'm running 245 45 18 on a Paceman with no clearance issues and my Speedo is dead on now, but that is the maximum width on stock 18" rims.
Old Jan 14, 2014 | 09:10 PM
  #85
HorseWithNoName
aries pushbar
Very nice setup...
Old Jan 23, 2014 | 07:33 PM
  #86
tominizer's Avatar
tominizer
Wonder if I could lift my Clubman S ?!?!??!? This is making me think bad thoughts .................
Old Jan 23, 2014 | 09:57 PM
  #87
bmwr606's Avatar
bmwr606
yes it fits ...,
http://www.crapindustries.com/cooper...kit/index.html
Old Jan 30, 2014 | 10:36 AM
  #88
RVNZ-R61's Avatar
RVNZ-R61
All the lift projects looks awesome guys!
Had a quick question, I wanna do this on my paceman. But it's front wheels drive, not the ALL4. How do you think this 2" lift change the drive? It seems like most of you have ALL4...
Thanks for any input!
Chris
Old Feb 12, 2014 | 08:06 PM
  #89
miniMAUL's Avatar
miniMAUL
aries pushbar
Just getting back on line after quite a while.
BF...Great looking MINI!
WWT...I have over 20,000 miles on the tires that went on same time as the list and no wear issues with routine rotations.
Also, put some new winter tires on the original OEM 18" rims and been getting thru these crazy winter storms just fine.
No rattles or issues with suspension with the lift over the same time/mileage. Looking to add a bigger rear sway bar this spring and front strut tower brace to try and tame the bit of the roll and push that going up instead of down has created.
Here is the latest pic.
Please keep posting photos of any of your lifted MINIs!
Old Feb 12, 2014 | 08:08 PM
  #90
miniMAUL's Avatar
miniMAUL
Chris
Wish I had a good answer for you but BF that posted the yellow MCS above would be a 2 wheel drive and may have some feedback for you.
Post back what you learn and what you decide.
Old Apr 29, 2014 | 03:40 PM
  #91
Whitephoenix's Avatar
Whitephoenix
Liftedddd
Just finish lifting my Mini monster.
Running 2 in lift from cooper crap with 235/55-18 tires.
No rubbing. Had to get 20mm spacer though.
Old May 13, 2014 | 04:35 AM
  #92
OldBeanRacing's Avatar
OldBeanRacing
Anybody in UK want to do a lift on a R53???
Cant find a lift kit here so where do I find one in the US?
Old May 13, 2014 | 05:05 AM
  #93
jlips's Avatar
jlips
Whitepheonix that looks badass!
Old May 13, 2014 | 06:34 AM
  #94
Whitephoenix
Update.
Thanks jlips, here you might like the update mini monster.
I give mini maul. Total credit for the roof rack idea. I just tweaked it a little to my liking.
Old May 13, 2014 | 06:49 AM
  #95
jlips's Avatar
jlips
What kin do roof rack attachment is that. I'm doing something similar to my R56 for my winter suspension setup
Old May 13, 2014 | 07:02 AM
  #96
Whitephoenix
Roof rack
It's the mini OEM roof rack bars powder coated gloss black to match the top.
The roof basket is from rage power sports got it for like 160 buck.
http://www.ragepowersports.com/cargo...-cargo-basket/
The lights I ordered from amazon and installed my self.
If you give me a. Couple mins I'll take pictures of the wiring and set up.
Old May 13, 2014 | 07:33 AM
  #97
Whitephoenix
Wiring
So I ran the wires inside the roof basket to get a clean look.
Then made a small connection on the side of the roof rack. (Super small and easy to disconnect if I wanted to take the basket off.
Ran the wires under the headliner.
To this switch. (Main power from batter so the lights would work even if the cars off. )
On a side note I washed my car yesterday and there were no leaks. ( that's why I haven't put the headliner completely back together. )
Old May 13, 2014 | 08:57 AM
  #98
jlips's Avatar
jlips
Yeah that would be awesome. Thanks a lot
Old May 13, 2014 | 06:09 PM
  #99
tominizer's Avatar
tominizer
How'd your run power to those lights on the rack?? That's cool BTW.
20mm spacers all the way around with that setup ?
I was talking to my service advisor about this lift. My CM only has 4000km on it now. He said to wait. Mini doesn't take kindly to covering suspension issues if you've put on non-factory parts that change the geometry.
Old May 14, 2014 | 05:13 AM
  #100
Whitephoenix
Setup
tominizer- yes they are 20mm spacer all way around. No rubbing with the tire and wheel setup. (That I have seen)
Only problem that I have is when jacking the car up the rear wheel touches the fender. But everything goes back to normal once the car is down.
