Suspension Question about IE fixed plate install
Old Apr 26, 2011 | 06:07 AM
Cole9953's Avatar
Cole9953
Do I carry this washer over to the new plates?
Old Apr 26, 2011 | 06:58 AM
jimz68's Avatar
jimz68
Yep!
Make sure to check the front toe when finished.
Jim
Old Apr 26, 2011 | 08:03 AM
Cole9953's Avatar
Cole9953
Just about done now. The connection to the swaybar us a PITA nylon lock nut, little Alan wrench, and a open end wrench with a seemingly unnecessary amount of threads.
Then it's off to the alignment shop, then some spirited testing
Is there any adjustment built in stock for front camber?
Crashton's Avatar
Crashton
Originally Posted by jimz68
Yep!
Jim
+1 ^ You MINI will now have toe in. Go to the alignment rack post haste.
EDIT.... There is no camber adjustment, just what the IE fixed plates give you. On my MINI with stock springs I have - 1.8 & - 1.9. If your MINI is lowered you will get more I believe.
Old Apr 26, 2011 | 08:04 AM
Vollgas's Avatar
Vollgas
Don't know if IE recommends any particular grease or not.
Helix recommends packing bearings in Antiseize.
Old Apr 26, 2011 | 09:06 AM
Cole9953's Avatar
Cole9953
They were full if grees when I got them, so let's hope that's good they are already on. I'm at stock hight I just hope it dosent end up more than 2*
Old Apr 26, 2011 | 09:48 AM
Cole9953's Avatar
Cole9953
At the alignment shop with some extra camber and the wheels I painted yesterday.
Old Apr 27, 2011 | 02:55 PM
Mike S's Avatar
Mike S
A quick question, what would happen if I had left that washer out on the installation of my coilovers?
Old Apr 27, 2011 | 11:51 PM
k-huevo's Avatar
k-huevo
The piece shown in the first post is a dust cover and helps retain grease. It serves no spacer function nor is it load bearing. The worst that can happen is a minor mess on the hat.
Old Apr 28, 2011 | 10:57 AM
Cole9953's Avatar
Cole9953
the bearings would be exposed, probably not a good thing.
also my alignment come out 0 toe and -1.8 camber on both sides.
Old Apr 28, 2011 | 11:41 PM
Mike S's Avatar
Mike S
Ahhh. I see! Thanks. I better get them re-installed ASAP.
Old May 1, 2011 | 02:28 PM
Crashton's Avatar
Crashton
Perfect!
Old May 1, 2011 | 03:10 PM
Cole9953's Avatar
Cole9953
here are some reference pics, for anyone in the future trying to figure it out..
how plate orientation should look installed
this is how i dealt with the pain in the *** drop links to the sway bar
and how i dealt with the shock nut
thats a spark plug socket, and the appropriate Alan wrench
W0TM8
Dec 19, 2019 07:50 AM
surfblue
Oct 24, 2018 01:20 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Minibeagle
Aug 13, 2015 10:00 AM
