Suspension M7.............
Old Jan 16, 2006 | 08:48 AM
  #151
KiLO's Avatar
KiLO
These types of threads are the types that make people leave NAM.
It does no good... I suggest we just move on.
Old Jan 16, 2006 | 09:01 AM
  #152
minimc's Avatar
minimc
Originally Posted by not-so-rednwhitecooper
what? you guys dont like bunnys with pancakes on their heads?
Nah... just need another underneath, so you can make a sandwich
Old Jan 16, 2006 | 09:14 AM
  #153
TonyB's Avatar
TonyB
I think you're right... For me, this one is only enough to make me unsubscribe. Which I'm doing now...
Oh, with re to the BBK question... From my experience, and what I've read, BBK's have not made for shorter stopping distances, or faster deacceleration. It does make for more consistent stopping distances, namely lessend fade with repetitive stops...
My BBK is 5.5 lbs lighter per wheel (most in the rotor), and with my wheels at 10.75 pounds, and tires at 19.8, the rotating mass to be overcome, or countered, is MUCH less than stock...
Old Jan 16, 2006 | 09:15 AM
  #154
Old Jan 16, 2006 | 09:45 AM
  #155
ScottinBend's Avatar
ScottinBend
BBK kits will decrease the stopping distance over a stock setup. The greater the area of the pad and rotor, the quicker you can get to the lockup threshold. This will shorten the time to come to a stop. Compare the old style brakes on a bicycle ( the clamp-type on the rim) to the newer disc type. Both are cable operated, but the disc type will stop much quicker because it has a much larger surface to apply the forces with.
Old Jan 16, 2006 | 10:04 AM
  #156
minimc's Avatar
minimc
Limiting factor of course being traction - tire to ground/size of footprint.
Old Jan 16, 2006 | 10:06 AM
  #157
TonyB's Avatar
TonyB
That was my original belief also, but after some healthy discussions in the Tire/Wheel/Brake forum here on NAM... Might be worth a new thread as the topic is an interesting one
For the reasons mentioned here though, even if there is improved deacceleration, I wouldn't expect the forces to be greater, and I would guess less as mentioned earlier due to an overall lighter rotating mass being stopped (wheels, tires & rotors)...
Ok, I really am unsubscribing
Old Jan 16, 2006 | 11:10 AM
  #158
jlm's Avatar
jlm
the lateral force of friction producing the braking effect is proportional to the vertical force and co-efficient of friction.
the vertical force is the wheel weight (as in corner balancing). Counter-intuitively, contact patch size doesn't have anything to do with it.
Old Jan 16, 2006 | 11:57 AM
  #159
minimc's Avatar
minimc
Doesn't have anything to do with which aspect?
I always thought a wider tire hooked up better & could stop shorter.
Or are you saying wider rubber would spread the weight out = less vertical force per measure of contact area, & therefore less co-efficient of friction... Yes? ...Sorry, still not sure I get you. ...Goes off to research
Old Jan 16, 2006 | 12:10 PM
  #160
ScuderiaMini's Avatar
ScuderiaMini
Old Jan 16, 2006 | 12:15 PM
  #161
dominicminicoopers's Avatar
dominicminicoopers
Tony, my mistake. I thought bigger brake rotors with bigger brake pads got a car stopped much quicker regardless of fade. Also of note, there's four wheels stopping the car and only two making it accellerate, making quicker accelleration potentially more damaging than that of potential damage caused quicker decelleration.
Old Jan 16, 2006 | 12:30 PM
  #162
jlm's Avatar
jlm
with respect to just basic friction, vertical force is the constant (corner weight) and that is what determines the lateral friction force (cornering and braking power). Pressure depends on how much area spreads that force out, so a wider contact patch will have the same overall vertical force, but less pressure.
Rolling tire grip is more complicated than simple friction, however.
Old Jan 16, 2006 | 04:51 PM
  #163
MSFITOY's Avatar
MSFITOY
Originally Posted by cooldaddy
no no no... user as in user of drugs, beers, modifications to Mini.
Sorry!
...are you clairvoyant or something Let me take the wheel of this thread and drive it off the cliff
Old Jan 16, 2006 | 06:10 PM
  #164
ScuderiaMini
please do so
Old Jan 16, 2006 | 06:19 PM
  #165
MSFITOY's Avatar
MSFITOY
Andy's in the middle of the road ....I can't avoid him...we're going too fast to make the turn and miss him...we're all gonna die...AAAAAAAAAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa THUDCRASHBANGKAPLOWEEZIINNGfssssssssss............ .threads dead
Old Jan 16, 2006 | 06:31 PM
  #166
