Suspension After lowering noise while turning
Old Jul 1, 2010 | 12:53 PM
johnbarleycorn's Avatar
johnbarleycorn
So I installed a set of H&R lowering springs and now I have a binding/clunking noise when I turn my steering wheel while parking or making low speed turns. Say I turn to the right it clunks and as I turn back to the left to center the car it clunks again. Everything appears to be tight, is it possible i over tightened my struts? I have read that it may be the strut rotating and rubbing in its housing. Any help or insight is appreciated.
B
Old Jul 1, 2010 | 02:05 PM
tvrgeek's Avatar
tvrgeek
My guess is the spring is not fully seated to the stops on the perch. You did use the original rubber spacers? Have you checked the sway bar links?
Old Jul 1, 2010 | 02:31 PM
johnbarleycorn
I put everything back on exactly how it came off. The front end links seem to be tight, i cant get them to budge with the alen wrench / crescent wrench combo.
Old Jul 20, 2010 | 01:59 PM
killerfox's Avatar
killerfox
did you find the problem, I'm having the same issue.
Old Oct 28, 2012 | 03:54 PM
Robert Sevilla's Avatar
Robert Sevilla
same here..... gah this is so annoying... small bumps and i hear this clunk. dealer told me it might be my my strut bushings. checjed tl sre if my towers mushroomed too. they're not. check all the bolts more than twice. made sure the eibach springs are seated correctly too. . do you guy think the dealer is right? i have a 2009 cooper s clubman.
rikaro
Aug 7, 2021 02:33 PM
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
patrioticmini
Aug 20, 2015 10:54 AM
damncajun
Aug 17, 2015 08:25 PM
