Suspension Wheels Flush with Fender Arches - Offset + Width
SuspensionSprings, struts, coilovers, sway-bars, camber plates, and all other modifications to suspension components for Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
For those who've added a wheel package to sit flush with the wheel arches, what width and offset do you have?
I can do the math from my OEM Challenge R112 wheels 17x7 wide @ 48mm offset, but need a reference point to confirm.
- Erik
Would be a 17", but that's irrelevant. Diameter doesn't affect wheel placement from centerline of the car.
It won't be on OEM suspension; either a Koni, Biltstien, or Tein coilover package.
Originally Posted by cmt52663
Ps: nice sig, but with respect -- that's "discipline" not "dicipline"
Charlie, thanks, appreciate it.
Originally Posted by slinger688
I run 17" Enkei PF01 with 38 mm offset..
What width? That's critical.
Have any images to show your current set-up?
Do mine count as sitting flush or would you say I poke Rally? lol
Definitely poke
Originally Posted by schatzy62
Rally, how about some pics with the Audi rims on the car.
These are 17x7.5 et40 205/40/17 and they come out to be just about flush...especially with the -6 camber in the rear. They do tuck unlike the BBS rs's, though.
running stock tires on my 17" crown wheels that are a 17x7 et48 I use a 15mm spacer on a slightly lowered car and the wheels are flush and do not rub. My aftermarket wheels are a 17x7 et 40 with a 235-40-17 Dunlop Star spec which have a very wide tread and they rubbed in the rear till I trimmed the plastic fenders. I then went to Yokohama Advan AD07s in the same size but found they were even wider then the Dunlops and rubbed again. Solved that problem with Bilstein HD struts.
You must not have many pot holes, and very nice roads. Or thats not a daily driver.
It's a daily driver. Just recently put on over 4k miles in May driving up and down the east coast to attend various car shows. Northern Ohio gets some pretty serious winters so our roads are ridden with the same potholes you see everywhere. Our roads are garbage here
