Suspension Trailing Arm Purchase? Who is cheapest?
Old May 18, 2010 | 01:27 PM
P1N HIGH's Avatar
P1N HIGH
I need to buy a new R56 right trailing arm. Mine broke and would like to know who is the cheapest.
Thanks.
Old May 18, 2010 | 02:32 PM
tvrgeek's Avatar
tvrgeek
BROKE? Wow. Bad news. Any details?
Darn big casting. What and how?
Old May 18, 2010 | 02:57 PM
P1N HIGH's Avatar
P1N HIGH
The thread you mount the shock on got stripped. I was gonna do a Helicoil, timesert or even considered JB welding it, but decided to buy a new one instead.
Old May 18, 2010 | 03:08 PM
tvrgeek's Avatar
tvrgeek
Great tip to watch out for. JB I would not do, but I did repair a lot of Al with the "Al solder" Of course, I melted a few parts too. You are probabbly wise to replace. If they are TOO expensive, might think about a good welding shop to tig it up.
I hate to pry, but was it stripped due to overstress in street use, or in race, or by cross-threading?
Old May 18, 2010 | 03:13 PM
P1N HIGH's Avatar
P1N HIGH
It was none of the above. It was stripped due to over torquing. The torque was set at the wrong setting. Was set at 100lbs. Just a really stupid mistake.
Has anyone done the swap? Do I need special tools and how hard is it to do? I can't find my TIS cd, when I need it the most. Arghhhhh.
Old May 18, 2010 | 04:52 PM
tvrgeek's Avatar
tvrgeek
You HAVE a CD! The rest of us just have to guess.
When you dig it out, I am about to get my Bilsteins, so what is the torque supposed to be, and what are the top bolts supposed to be?
Old May 18, 2010 | 08:47 PM
P1N HIGH's Avatar
P1N HIGH
Shocks to Rear Trailing Arm is 165nm
Strut support to body is 56nm
Old May 19, 2010 | 12:45 AM
ndylam's Avatar
ndylam
The new trailing arm would cost you $330. I would suggest using the Heli-Coil. Why ? because I was in your shoe. I tripped mine when I was installing a new set of coilovers. I fixed it with the Heli-coil. It's actually stronger than before because the thread is now steel instead of aluminum.
I still have the Heli-coil and am more than happy to sell it to you. Send me a pm if you're interested.
Old May 19, 2010 | 01:12 AM
ndylam's Avatar
ndylam
1. Remove the trailing arm.
2. Drill a new hole using drill bit size 14.25MM or 9/16.
3. Tap the hole with M14-1.5 size.
4. Install 2 Heli-Coil inserts into the newly tapped thread. Install the 1st insert then remove the tang then do the same for the 2nd insert.
Honestly, I'd suggest you bring it to a machine shop and have them drill the hole then tap it yourself. It would cost you $20-$50ish depends on the shops. Still, that is way less than buying a drill and the special drill bit size.
Old May 19, 2010 | 07:33 AM
Creeve's Avatar
Creeve
Does anyone know the original thread pattern of the bolt?
Old May 19, 2010 | 11:34 AM
P1N HIGH's Avatar
P1N HIGH
Thanks for the write up. Just a quick question? Shouldn't I be tapping it larger given the bolt size is M14.1.5?
Old May 19, 2010 | 11:37 AM
P1N HIGH's Avatar
P1N HIGH
The spec for the bolt state M14x1.5x101
Old May 19, 2010 | 12:16 PM
tvrgeek's Avatar
tvrgeek
take bolt and arm to a machine shop. They should have the heli-coils and tool.
I am surprised it is built that way. Usually suspension is through-bolted.
Old May 19, 2010 | 02:59 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
You could also just get a longer bolt and put a nut on it.
Old May 19, 2010 | 03:21 PM
tvrgeek's Avatar
tvrgeek
Maybe viable. I am not looking at one, but does it have enough meat in it? This is a bolt used in a cantilever ( bad design actually) and I would be very concerned with it pounding the hole oval and eventual failure. You would want to ream the hole to a snug fit of a proper long bolt so no threads were inside the arm. Helicoil is easier.
For those interested in how to, or not to, design a chassis, I recommend Carrol Smith's series of books. Build to win, Prepare to win, Tune to win. Yes, books, not internet.
Old May 22, 2010 | 07:32 AM
tvrgeek's Avatar
tvrgeek
Put my new rears on. I do see that the shock bolt is a through hole, lots of meat.
As the shear is taken by the shock conical bushing, a through bolt would not worry me as TS mentioned above.
The torque spec mentioned above scared me. Taking them out, they were at about 85 FtLb. I torqued them to 90, about 115 nm. 165 just seems really high.
Old Jun 26, 2010 | 07:52 PM
juchong's Avatar
juchong
The official BMW spec is 121 ft lb for shock to trailing arm and 45 ft lb for strut to chassis FOR THE REAR.
wkp1219
Nov 13, 2015 07:52 AM
TunedGP
Oct 1, 2015 04:18 PM
Jcwlemon
Aug 31, 2015 08:37 AM
smarsha11
Aug 24, 2015 06:03 AM
Mini-Hype
Aug 17, 2015 06:32 AM
