Suspension Need confirmation--are adj. front end links supposed to be set shorter or longer?
Old Apr 17, 2010 | 07:10 PM
D Unit's Avatar
D Unit
I just installed some Alta front end links and adjusted them as short as possible. Then I read somewhere else that I should have done them longer which is kind of anti-intuitive for me I guess?!
So, is it supposed to be longer or shorter in the front???
Old Apr 18, 2010 | 05:51 PM
slinger688's Avatar
slinger688
The best is to adjust them so the sway bar is horizontal in position (---) when the car is sitting on a flat location. If you have a good friend, you can get in the car and he can adjust all four adjustable end links (both front and rears) so that they are all horizontal.
Old Apr 18, 2010 | 06:18 PM
ron-s mini's Avatar
ron-s mini
Texas Speedwerks Install instructions have great information:
http://www.txwerks.com/images/Instal...ks_install.pdf
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
FatherG
11
Aug 7, 2015 07:49 PM
