Suspension Replace ball joints with control arm bushings?
At 85k my car is handling erratically and feeling really jumpy when moving throttle back and forth between 0% and 15%. Turns out the control arm bushings are shot.
I want better quality and stiffer bushings if I'm going through all the work to replace them so I'm going to go with Powerflex bushings.
I am considering doing the ball joints at the same time but I'm wondering what their life expectancy is and if it is worth it to replace them.
I can get the bushings for $90
or
Kit for $299 that includes:
1 set front powerflex control arm bushings
2 outer ball joints
1 Left inner ball joint
1 Right inner ball joint
How much more work/labor is involved to do the ball joints as well?
or
2 outer ball joints
I think I'm going to try out these new BSH lower engine mounts:
BSH R53 Lower Engine Mount
http://www.bshspeedshop.com/store/home.php?cat=1141
124,000mi. and just replaced my LCA bushings with the powerflex and my ball joints were fine. WOW, the car is new again after the bushings were installed. My VIP engine mount's bushings are going so they're next on the list. I also just ordered BSH's lower engine mount too. FUN!
Yeah my upper motor mount is bad and I've read that can kill the lower one too.
), so I was thinking of replacing the ball joints together. Based on the feedback in this thread, I guess the ball joints can wait.
http://www.txwerks.com/servlet/Categ...%3AMotor+Mount
With your car at 85k, why would you have it all apart to do the bushings and not change the ball joints?
I did all my ball joints when I did my bushings...there was no way I was going to have the subframe laying on the floor and not do the ball joints while I had the control arms off.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
