Suspension Warranty info
Old Nov 21, 2008 | 06:39 PM
MiniLove247's Avatar
MiniLove247
Warranty info
how will lowering my car effect my warranty?
Old Nov 21, 2008 | 07:20 PM
IzzyG's Avatar
IzzyG
I believe any warranty claim will be up to the discretion of the dealer/MiniUSA. However, denying a warranty claim needs to be supported with evidence that the damaged part is because of your modification. As far as issues with lowering your car goes- your struts are probably the main concern if you're doing springs only. In other words, if your engine blows, they cannot deny a warranty claim based on the fact that you lowered your car. Or at least I don't believe so. :P
Old Nov 21, 2008 | 07:29 PM
ltdodge's Avatar
ltdodge
well here in orlando, someone lowered thier clubman and afterwards the radiator hose came loose and was rubbing on the ground without them knowing. the engine overheated and I think they kept driving and blew the engine...... the dealer denied warranty because if the car was not lowered the radiator hose would not have rubbed a hole on the ground.......
Old Nov 21, 2008 | 07:54 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Well that covers it well. I'd check with "your" dealer and make a note of who you talk too and what was said. I've also heard some dealers deal with different springs differently based on how much a given spring lowers a car.
By the way, how low does a Clubman need to be to drag a radiator hose?
Old Nov 21, 2008 | 08:00 PM
ltdodge's Avatar
ltdodge
the radiator hose apparently came loose and was dragging on the ground.....
this is what the dealer said.....
Filmy
15
Jun 6, 2023 06:27 AM
LifeAfterBeetle
Sep 19, 2022 04:55 AM
02proxdude
Sep 22, 2015 06:44 PM
MiniUnz
Sep 14, 2015 11:11 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
