Suspension BC Coilovers and JIC/Cross Coilovers
I was originally looking to get the CROSS, but the price was too much to swallow on daily driver justacoopa. I went with the BC instead and have no regrets.
Also, COR BLMY has a fantastic write up to install them and make the neccessary modifications to the front to adjust camber easily, and to the rear so you don't have to remove the shock to adjust it.
how good are Megan coilovers? Thats what Dopamine runs on his car. I plan on getting them $840 http://store.nationalspeedinc.com/gr...ducts_id=52737
I do have to say that the stance ones look good as well. But the same thing, they look identical to the BC's, Cross. It's just so hard to make the right decision as it is a bit of money to waste if you buy the wrong ones!!
Well, I never heard bad things about the BCs. I've never heard bad things about the Cross either, but they cost more than twice the BCs!! considering that I'm not going to track my car everyday, I'm pretty sure the BCs will be good enough for me
Stance, I didn't hear anything about them, but I'm sure they are good, still they cost more than the BCs offering the basically the same. Maybe having only 15 adjustement positions may make it easier to find the right one, but is this worth over 300 $?
The stance ones are both front and back inverted monotube and the rears are adjustable from the bottom of the strut, which is a huge plus for me. I don't want to have to rip my interior to cut holes, that's just stupid I think. I think I am going to go the stance Coilovers, just gotta find a good source to buy them off now Thanks guys for all your input, I know everyone has their own opinions and you just have to take what you think is right from them. My car will only do the occasional track day, when I get time.
www.nationalspeedinc.com these guys carry Stance products. They dont have them on their site for Mini's but if you call them they will get you some. I'm getting all my work done there. I'm getting the Megan coilovers cause I wont be tracking at all just want a slammed mini on 18's
Anyone looking for true slam abilities should look into coilovers like the KW V1's
just when I think i know what I want....the guy at National Speed tried to sell me the KW 's but when asked Dope what he was running. I'm really confused about what to do now. This will prolly sound a little rediculous but I dont really dig the yellow and purple coloring in the KW's. I'm trying to build a show car with a black and red theme. The Megans would match along with Cross. What to do what to do?????
In terms of color at the shows. Unless you plan on removing one of the wheels and using those wheel display plates....no one will be able to see the red parts of the Megans. They're usually tucked too deep under the car or up in the strut tower.
I'd rather have a teeny tiny purple perch peeking out way behind my wheel than having super ugly wheel gap
(especially on big 18s).
If it's a true show car, it'd be worth it to grab the KW's and just take the perches to be painted/anodized/powdercoated to red or whatever other color you needed. That way it would match your scheme and you would be able to have a show-worthy stance as well.
(especially on big 18s).If it's a true show car, it'd be worth it to grab the KW's and just take the perches to be painted/anodized/powdercoated to red or whatever other color you needed. That way it would match your scheme and you would be able to have a show-worthy stance as well.
If you're going to be running 18's AND you're going to participate in car shows, you will more than likely be disappointed in the amount of drop you will get on the front from the present day Megan's/BC's. I was able to get a 1.5 inch drop "at best" with the Megan's and that was with the collars spun all the way down and sitting on top of each other. Running with the system slammed all the way down then caused problems in other areas !
If you want to be able to drop 2 inches and more, than you will need to go a different route. KW is certainly one brand that will give you that kind of drop. I myself went with a set of Cross coilover's ! They are considerably more expensive then some other set ups but in my case, they were worth every penny !
Has anyone tried the Stance and can give feedback on how much they lower, how easy they are to install (I know BCs require trimming of the strut tower holes to allow the camber plates bolts to be reached when you need to adjust them) and the quality of the ride on street?
The strut towers "do not" need to be trimmed !
[quote=ninjlao;2534832]I would have to say that the coilovers you want to buy will really depend on how you're going to use them. If you're going to track/autoX go for the CROSS.If you're not going to be seeing much track time go for the BCs.
Wait who is this ???
I track, SOLO 1, and auto X, on the BCs .. what series are YOU running ???
BC IS the mfg they do make other units to STATED specifications ...
The BC BR Series... SURPASS any of the clients that have them branded !!!
To their own spec
To their own spec
you mean on the BCs or on the Stance? I saw COR's write-up on the BC install and it was stated you needed to cut the strut tower holes to allow clearance for the camber plates bolts otherwise you wouldn't be able to reach them...
