Suspension TSW X Brace impressions & updates
Old Mar 6, 2009 | 12:08 PM
  #151
OldRick's Avatar
OldRick
If pressed, they will ship to the US for 29GBP (about $44) instead of the 39GBP they first quoted me. It's still a rip-off...
Old Mar 13, 2009 | 07:00 AM
  #152
DaveTinNY's Avatar
DaveTinNY
Every time I see the X-Brace ad in MC2 Magazine I drool... Good feedback, everyone. I think I'll be buying one of these in the near future.
Old Mar 14, 2009 | 06:10 PM
  #153
Mini_Joe's Avatar
Mini_Joe
Impressions on the X-brace?
It's very pretty sitting on my living room floor, and the cat loves to rest her head on the ends!
I'm having to wait to get my exhaust worked on before installing it... and the suspense is killing me!
Old Mar 25, 2009 | 05:19 PM
  #154
OldRick's Avatar
OldRick
GTT Mid brace
I got the GTT mid-chassis brace installed today - it's impressive. Here's the review: https://www.northamericanmotoring.co...hp?product=360
I think that, with a forward-trapezoid lower frame brace it is at least as effective as the x-brace, and without the loss of ground clearance and added noise and vibration. I Like it!
Old Mar 25, 2009 | 11:07 PM
  #155
Mini_Joe's Avatar
Mini_Joe
Well, I finally got the X-brace installed on Friday, and have about 300 miles on it so far, mostly highway miles from LA to San Diego.
No added NVH that the wife or I can sense, but then again, it's on a convertible...
What we did notice was the steering wheel has much less movement in it... remarkably so.. even on our 8k mile car.
Everything just feels more solid. You'd think there was a roof on it... it's that nice.
And like others have also mentioned, greatly reduced vibrations in the rear view mirror as well... I can actually make out the headlights clearly at night!
I took it for a short trip down the local twisty roads... the car felt much more stable.
Old Mar 27, 2009 | 06:15 PM
  #156
the platform's Avatar
the platform
Finally Got Mine!!
Bought my X Brace from Way yesterday @ AMVIV. It went on this morning.
Everything feels great.No probs to report.
I can 2nd everything MiniJoe just posted.Next are poly bushings for control arms.
Old Dec 18, 2009 | 08:18 PM
  #157
AutoXCooper.com's Avatar
AutoXCooper.com
I was informed by TSW today that those 1st Gen MINI's running the Miltek catback have had issues with the 1st Gen XBrace being hit by the exhaust under load. The Good News is that you can replace it with the R56S/2nd Gen XBrace which sits a little lower for the OEM down pipe and also works well on the 1st Gen MINI' with Miltek Catback system.
Install is the same. If you have an R53/52/50 with a aftermarket catback that sits lower then the OEM near the cat you may need the R56 XBrace.
Old Dec 21, 2009 | 09:21 AM
  #158
Mini_Joe's Avatar
Mini_Joe
I wonder if this is part of the issue I've been having with my aftermarket header/cat combo?
The exhaust is still stock, but the front half isn't factory anymore.
I'll have to climb under and take a look for spots where there might be clearance issues...
Old Aug 1, 2010 | 10:25 AM
  #159
jonasandezekiel's Avatar
jonasandezekiel
The downside might be some ground clearance issues....no?
Old Jan 18, 2018 | 10:02 AM
  #160
torogi's Avatar
torogi
I just installed this Xbrace on my new to me MCS, and it is awesome! One thing though, does anybody have experience with the end corner bottom side of the cat converter hitting the brace on the V/x part? under hard acceleration or shifting i hear a rattling noise, i suppose since the exhaust is 'floating', it is hitting that part.
Old Jan 18, 2018 | 10:42 AM
  #161
RB-MINI's Avatar
RB-MINI
Yes, the cat hitting can be an issue, especially if you have worn or broken motor or exhaust mounts. It also depends on the manifold, but I've heard it even with the stock manifold.
If you're not worried about ground clearance, the R56 brace is supposed to fit but has more clearance under the exhaust because of the difference in the turbo downpipe.
Old Jan 18, 2018 | 10:46 AM
  #162
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
how awesome?
Can you please elaborate on what differences that you found making it awesome?
Old Jan 18, 2018 | 10:58 AM
  #163
torogi's Avatar
torogi
I'll check with Way what is the best way to address the fitment issue. I do have stock manifold (JCW).
I only drive street, so elaboration maybe limited. I could describe it as more nimble handling. I have only driven it less than 30miles but so far I am liking it.
Old Jan 18, 2018 | 11:55 AM
  #164
torogi's Avatar
torogi
Just heard from Way, add washer/spacer on the bolt towards the back end (not on the mount). I will try that today.
Edit: installed a quarter inch spacer on both rear bolts and it cured the rattling!! motor on!!
Old Feb 6, 2018 | 10:34 AM
  #165
KCLARK's Avatar
KCLARK
Per Post #144: THE ITCH suggested using longer M12 x 1.5 grade 10.9 bolts, four washer/spacers to equal the depth of the cavity and a brace with four 12mm holes drilled in it of the appropriate length.
Is this the solution to mount the TSW X-brace if you have a larger diameter exhaust? My mechanic told me I cant use the brace since its hitting the exhaust but says I need to get longer bolts and washers. So I'm just confirming if what THE ITCH said is the solution?
Old Feb 6, 2018 | 08:30 PM
  #166
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you can put spacers on and use the stock bolts. If you go over 1/4 inch I would get longer bolts. But this is common to clear larger exhaust or sagging exh mounts.
On the ALL4 R60 we actually use a bolt about an inch longer for the front bolts due to the subframe shape.
Doc Pain
Mar 10, 2021 04:50 AM
YaTuSabe
Aug 23, 2018 11:41 AM
minieater
Oct 28, 2015 02:15 PM
potterstein
Oct 1, 2015 07:10 AM
gnhovis
Sep 28, 2015 10:56 AM
