Suspension Shaking when accelerating after installing HR springs
Hi guys,
Today I had HR 30 mm lowering springs fitted on my '08 MINI Cooper D at my local auto mechanic (read: not a auth. MINI workshop).
I took it for a test run, and noticed that when accelerating relatively hard (especially in 2nd gear), the front end of the car shakes. It shakes when it is in the low end of the RPM's and eases out when it reaches the higher end. But i'm almost sure that it is not because the engine is under a heavy load.
It didn't do this before the springs were installed.
I had my mechanic take a drive in it, and he could also feel the shake.
He had the car on the lift again, but couldn't think of why it would behave as it does.
The wheel bolts are tight and everything..
HELP!!!
Sincerly
a sad MINI driver
HELP!!!
Sincerly
a sad MINI driver
Have a look here as well:
https://www.northamericanmotoring.co...after+lowering
Some cars have it and some do not. It is caused by the inner cv on the passenger side.
melscoop
Mar 30, 2016 06:56 PM
squawSkiBum
Oct 2, 2015 09:21 AM
